preping edelbrock stepped headers
Old Nov 1, 2004 | 02:03 AM
xxboomer408xx's Avatar
Exclamation preping edelbrock stepped headers
I just got my edelbrock stepped headers and was wondering if its worh ceramic coating them. i was also thinking about spraing them with vht high temp silver paint. it says it will hold up to 1500 degrees. how should i take off the black paint thats on their?
Any feed back is welcome!! thanx!!
Old Nov 1, 2004 | 12:37 PM
ttt !!!!!
Old Nov 1, 2004 | 12:59 PM
KB99WS6's Avatar
I'd say its definitely worth it if you want them to last much longer and not be covered in rust after 1 year.
You should have them sandblasted, or else just take some sandpaper to them to rough up the surface so that the VHT paint ahderes better. I just bought coated Pacesetter's and used the VHT flameproof clear coat (1200 degrees). I just cleaned the suface with alcohol and than sprayed 2 coats over the coating just to give some added protection. Winter is coming
PS- I have also heard barbeque paint (you can get this at home depot-its cheaper than VHT) holds up even better than the VHT, I didn't use it though b/c I wanted clear so you could still see the nice finish of the headers ( they look like jet-hots).
Old Nov 1, 2004 | 01:37 PM
Z28Venom's Avatar
I highly recommend the ceramic coating.. My painted headers looked like *** after I first started the car.
If you do paint them, have them sandblasted. After the sandblasting use POR 15 or POR 20 high temp paint to coat them.
Old Nov 2, 2004 | 01:21 AM
how much does coating cost? should i weld on the collectors and egr and air stuff then have them coated. or weld them after the get coated?
Old Nov 2, 2004 | 01:42 AM
Z28Venom's Avatar
Speed Inc. charges 279.99 for inside/outside coating of LS1 longtube headers. I'm not sure how much it cost for the jet hot coating.
You definitely want to have everything welded before you get them coated.
Good Luck..
Old Nov 3, 2004 | 12:55 AM
do u think i'll get that much of a gain if i coat them or should i just coat them?
Old Nov 3, 2004 | 07:15 AM
KB99WS6's Avatar
Does anyone else think it's a little ridiculous what these places for coating??
boomer, you will get a little gain, but more importantly they will last a lot longer (not to mention look a lot better than rusted manifolds)
Old Nov 3, 2004 | 10:25 AM
Matt D's Avatar
Retired Street Racer
jet hot charges the smae as speed inc., i just talked to them about the edelbrocks...i am going to wait til the new ones come out
Old Nov 3, 2004 | 12:47 PM
git_sum's Avatar
When are the new coated edelbrocks coming out? And how much are they gonna cost?
Old Nov 3, 2004 | 02:53 PM
Matt D's Avatar
I have no idea what you are talking about...they are coming out after SEMA and the sponsors, i.e. SDPC, should have them 2-3 weeks later
Old Nov 4, 2004 | 07:03 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
I am definitely going to wait and see how the new 'bolt on' edelbrocks are. I hope they retain the high velocity merge, but just pre-weld it on and add the O2 bungs.
Old Nov 5, 2004 | 02:28 AM
35th SS's Avatar
thinkin about swappin to these.but Ill wait .
Old Nov 5, 2004 | 06:09 AM
UNDER PRESSURE MOD
Anyone get any pics from SEMA yet.... I haven't seen any posts... I'm sure somebody from this board is there and taking pics....
Old Nov 5, 2004 | 10:03 AM
Matt D's Avatar
i searched the whole sema site and could not find anything on them, and checked edelbrock's website as well...it should only be a few weeks, well worth the wait
Old Nov 5, 2004 | 12:19 PM
UNDER PRESSURE MOD
Most definitely.... I am going to wait and see what they look like and then make my decision between these and the Pacesetters with the TSP offroad y.
Old Nov 5, 2004 | 12:28 PM
Matt D's Avatar
the edelbrocks are the way to go...they are cheaper and so much better than pacesetter, especially if you add more power down the road...i am just waiting to see the price vs. the painted ones...if it is too much i will have jet hot or speed inc. coat mine inside and out...the pacesetters are only coated on the outside
Old Nov 5, 2004 | 02:11 PM
UNDER PRESSURE MOD
Well according to the post from the guy at Edelbrock.... the Ti-teck (or whatever its called) is cheaper than ceramic coating by a good amount. So I would guess that it would be an additional $50- $100 for the Ti coating. Hopefully they won't jack the price for welding on the collectors and O2 bungs.
