Why won't my car start on the first try anymore?
-KP
to diagnose have somebody turn the car on and just before the fuel pump kicks off with the key in the run position use a pair of vice grips and pinch the fuel line shut. if the pressure holds at that point then the injectors are good and are not bleeding off. once you release the vice grip and the pressure bleeds off then its the regulator and in some cases the fuel pump. i had this issue with my car with the later returnless style system and turned out to be the fuel pump. replaced with new walbro 255lph with new harness and fixed.
starts up the first time, every time.
also if you get the oem replacement pump kit, they do typically come with a new harness to fix the crappy original design that was causing the pumps to fail prematurely.
hope this helps, happy wrenching
I've only heard rumors of very early 98 models having the fpr on the rail, but I've never seen one. It would also mean there would be two pump part numbers for 98 models, but there are not. I believe a preproduction 98 fbody was used for testing for a few vendors which had an fpr on the drivers side rail, but again I've never seen one. I've had quite a few 98's, and I can remember seeing a few x code vin 97 trans ams on ebay a few years back. (Mostly incomplete vehicles, but they were listed as registerable and street legal)
I had a typhoon intake a loong time ago and it said 98's needed special adapters but mine did not.
So I believe the fpr on the rail for 98 models is a myth
