Egr/air Blockoff/removal?
You can purchase them directly off the site www.mycamaroz28.homestead.com
It is difficult to create a "cheaply made" product that is fairly simple in design mimicking the stock shape using high-quality materials and polished to a high-luster. I understand that we cannot satisfy everyone 100% of the time. I am uncertain how there could be any improvements made though we are open to suggestions.
If you are unhappy with the quality, feel free to return it to us, and we will be happy to give you a refund. We certainly do not want someone to be unhappy with their purchase.
Steve
Pres.
There is no benifit to use thicker T6 grade material. If lower grade less expensive more ductile material was used, then it would be necessary to use a thicker material (to prevent warpage). Thicker 6061 hardened to T6 only adds more cost to the parts which is passed to the consumer.
Regarding the hole or edges, they are all CNC cut and milled. Polishing can alter the final finish and shape of holes since material is removed.
Regarding making one less expensive. I agree whole hearted, sometimes if you have the material and equipment, there is a certain pride that making a part yourself lends to a feeling of self accomplishment. If you have access to the material for free, have access to various polishing compounds for free, then yes, there is no doubt that you can make the part less expensive. If one went out and purchased a piece of 6061 T6 material and appropriate polishing material...cut it out with their method of choice, it may end up costing around the same amount. There still is that "I made it myself" accomplishment feeling that you would still take pride.
As you have mentioned and we agree, 15.00 shipped for a part made out of high-grade material that is polished we feel is extremly reasonable.
I do appretiate your feedback.
How about someone just calls up Alcoa metals and asked for some aluminum stock... I wonder how "cheap" it'd be for you to manufacuturit yoursefl then
