LT Headers and emissions sniffer test
Old Nov 15, 2004 | 08:40 AM
S2002S's Avatar
Default LT Headers and emissions sniffer test
I have recently begun using a scanner and I noticed that the performance of the O2 sensors are not normal due to their relocation (cooler exhaust temps). Has anyone had problems passing the sniffer test, assuming that cats are present?
Thanks!
Brad
Old Nov 15, 2004 | 11:28 AM
Z28Venom's Avatar
Thanks!
Brad
Their location probably isn't the problem. They're probably on their way out. Also you can pass the sniffer with LTs and cats.
Old Nov 15, 2004 | 11:46 AM
PonchoFan's Avatar
My header/cat installation threw a code for low converter performance.
It is because the converters are further away from the exhaust port and don't heat up
enough. It took 100 milres of driving to throw a code.
You can either put in O2 sims or have the code deleted with LS1-Edit.
