ASP vs March! About to order...need advice
Old Nov 15, 2004 | 01:03 PM
hepcatws6's Avatar
Default ASP vs March! About to order...need advice
Ok, guys...here it is. I am about to order my underdrive pulley from Thunder Racing...which should I go with? Should I get the ASP or the March? Thanks in advance.
Old Nov 15, 2004 | 01:04 PM
Cefiro's Avatar
ive heard good things about ASP, thats what im going to go with. Ive never had any personal experience with either though.
Old Nov 15, 2004 | 01:08 PM
hepcatws6's Avatar
I went back and checked out an old thread I posted about pulley's and it was a toss up between the two. Most people seemed to recommend the March, though, since it is fluid dampened.
Old Nov 15, 2004 | 03:26 PM
LS1BirdDRG's Avatar
11 Second Truck Club
I ordered the March pulley from SDPC last Friday. Soon as I get it I'm installing it so i'll let ya know what I think.
Old Nov 15, 2004 | 03:45 PM
mitchntx's Avatar
Exactly why I chose the March over the ASP.
My March has seen 3 road race weekends ... no issues at all ...
Old Nov 15, 2004 | 04:27 PM
Another_User's Avatar
What he said.
Old Nov 15, 2004 | 10:00 PM
wrencher's Avatar
wrencher
I like the fact the march is fluid dampened for one. Another reason I like them is because they weigh near stock, smaller yet near the same weight. You don't want less to dampen crank harmonic's IMO. I've had mine for a year, to many passes to count & prolly 7K on it > no problems + w/ a roll master double T-chain. No mods bolts right up.
Old Nov 21, 2004 | 11:23 PM
LS1BirdDRG's Avatar
I just installed the March pulley and it seems to rev noticably better in the high rpms. I had just a slight vibration it seemed before between 6k and 6600 rpms. It's gone now so I'm sold on the March pully and very happy with it.
Old Nov 22, 2004 | 01:09 AM
BriancWS6's Avatar
March here as well.
Old Nov 22, 2004 | 09:44 AM
P Mack's Avatar
March here too. ASP is about 4 lbs lighter but doesn't have fluid dampening. You probably won't notice the difference between the two.
Old Nov 22, 2004 | 12:24 PM
demonspeed's Avatar
It's not mine! woo hoo!
What's so good about fluid dampening?
Old Nov 22, 2004 | 06:48 PM
SpeedDreaming's Avatar
Nothing necessarily, through stock RPM ranges. I've often wondered if you aren't worse off in the lower ranges in terms of harmonics and engine balancing with a FD .These things are best for high-rev applications IMHO.
Old Nov 22, 2004 | 07:15 PM
May help smooth idle a little, but probably not noticeably.
Old Nov 22, 2004 | 09:20 PM
ULTIMATEORANGESS's Avatar
ive had my ASP on for almost 4 years with no problems.
Old Nov 22, 2004 | 09:46 PM
Phil99TA's Avatar
Another vote for ASP here
Old Nov 22, 2004 | 09:58 PM
FAST LS1's Avatar
+1
If the March pulley really is 4lbs heavier than the ASP some of the benefits of a lighter smaller pulley are lost with the March. I would assume the ASP would show more hp gains and I've never heard about any problems with the ASP.
I will be installing my ASP pulley this weekend if the pulley installer threaded rod comes in that I ordered from code4.
Old Nov 22, 2004 | 10:00 PM
bigdsz's Avatar
March for above reasons.
Old Nov 22, 2004 | 10:07 PM
ss rally red's Avatar
Year and a half with ASP/no problems.
Old Nov 22, 2004 | 10:13 PM
P Mack's Avatar
It looks from his sig like he already decided, but I would say:
-Get the March for peace of mind (even though you don't need fluid damped)
-Get the ASP if you're looking for every last bit of hp (even though you probably won't feel the difference from the march)
-If you're still undecided, get the one that's cheaper.
Old Nov 23, 2004 | 07:27 AM
demonspeed's Avatar
Well, considering I'm going with a G5X3 that likes to rev, I might be better with the March - then again, I've heard nothing but good things with the ASP. I'm sure the stock pulley isn't fluid-dampened, and I know that works fine with that cam.
