View Poll Results: Header bolts ..... Lock tight or not
Lock Tight on the bolts
11
29.73%
just put them in
26
70.27%
Voters: 37. You may not vote on this poll
Header Bolts
Old Nov 16, 2004 | 06:29 AM
00Camary's Avatar
Default Header Bolts
Header bolts.....lock tight or just put them in.
Old Nov 16, 2004 | 07:10 AM
GeorgeC's Avatar
Just tighten them to spec, then be sure to recheck after a few hours of run time... It never hurts to check them from time to time afterwards, either.
Old Nov 16, 2004 | 09:07 AM
Keenov's Avatar
Stage 8 locking header bolts
Old Nov 16, 2004 | 09:28 AM
GuitsBoy's Avatar
I used just a hint of high temp red locktite and never had a problem. Checked after a couple of days and they were still tight. I check every couple months and not a single bolt loosened up.
-Tony
Old Nov 16, 2004 | 10:10 AM
conan's Avatar
I asked the same question when I did my studs. I got more responce to use high temp anti seeze. I used the anti seeze on threds going in to the heads and nothing on threds with the nut. Retorqued About 3 times have not had any problems.
Old Nov 16, 2004 | 03:10 PM
LawmanSS's Avatar
I just torqued mine to specs...
Old Nov 16, 2004 | 03:12 PM
Cefiro's Avatar
id reccomend getting stage 8 header bolts
Old Nov 16, 2004 | 03:59 PM
black_z's Avatar
I used a medium grade lock tite.
Old Nov 17, 2004 | 02:01 AM
jrp's Avatar
jrp
SN95 Director
Old Nov 17, 2004 | 02:23 AM
2MuchRiceMakesMeSick's Avatar
I use stock bolts and they have never backed out on me. None of my freinds either.
Old Nov 17, 2004 | 04:01 AM
JJ1965's Avatar
Antisieze is awesome! I always check header bolts a couple of times after install, but the antisieze helps alot when you remove them.
Old Nov 17, 2004 | 01:09 PM
S2002S's Avatar
The shop manual says to use loctite.
Brad
Old Nov 17, 2004 | 01:24 PM
Z'mnypit's Avatar
2nd that!! I run the stage * locking bolts & havent had to tighten any of them yet!
Old Nov 17, 2004 | 08:32 PM
code4's Avatar
I've have heard many different opinions on this. And to be honest I was going to re-use my stock bolts without locktite on my headers. But guess what, there was thread locker on my stock bolts when I removed them & I had work my butt off to remove it off of the threads before reinstalling. It was some hard crap. This is on an 01, maybe different on other years?
Bottom line is that I reused my old bolts and used med locktite since the factory had used thread locker. So far no problems.
Old Jun 22, 2005 | 09:59 PM
Schantin's Avatar
If you ever want to get those bolts out of the head again....suggest anti-seize Another vote for the Stage8 bolts as wel.
Old Jun 22, 2005 | 10:20 PM
blkZ28spt's Avatar
Oops, I just voted for loctite without thinking about it. I use anti-seize and don't torque them to spec b/c I can't really get a torque wrench on a lot of them so I guestimate.
Old Jun 22, 2005 | 10:58 PM
SIK02SS's Avatar
sooo..best case scenario...anti-sieze and stage 8's?
Old Jun 23, 2005 | 12:08 AM
Lithium's Avatar
SSU's Drunk Typing Whore
I could not get my torque wrench on a couple bolts, I just guessed. But just use some anti-seize and tighten them up.
Old Jun 23, 2005 | 01:13 AM
calongo_SS's Avatar
Anti-seize here, and no torque wrench. I just guestimated as well, then checked the ones I could easily reach a few days later.
Old Jun 23, 2005 | 01:31 AM
bayer-z28's Avatar
Ok, so I'm NOT insane! My install/part Guys at East Side Performance told me that the stockers are fine. I'd never use LockTite on aluminum heads, well mabie a hint of the blue LockTite...
I put 400 miles on my headers when I was back home and the bolts are still tight. I checked them after 100 miles and they were all fine. I ordered the ARP lockers when I purchased my Random Tech cats and I never got the bolts!! UPS is pissing me off!!!
LITHIUM: I could not get my torque wrench on a couple bolts, I just guessed.
Same here. Got every one TQ'd except the VERY rear bolt on the PASS side. I couldn't get my TQ wrench to sit on the bolt head properly...no go....
