Metco breather
Old Nov 16, 2004 | 11:09 PM
pdd's Avatar
pdd
Default Metco breather
who's using one. any pros-cons. i have a catch can and still have oil consumption. i was wondering if this will help me. thanks pat
Old Nov 17, 2004 | 10:37 PM
BAM-BAM's Avatar
i had the breather and catch can setup and it helped but did not get rid of the oil consumption completely....i did that on the new motor by removing the pcv system and just using breathers...and have not used a drop and no problems running with out the pcv
Old Nov 18, 2004 | 05:44 AM
Slowhawk's Avatar
LS1Tech Sponsor
Just make sure you delete the PVC system completely if you go with an open filter on the valve cover.I've had good luck with a LS6 PVC system with the catch can.
Old Nov 18, 2004 | 12:17 PM
C4VetteLS1's Avatar
I found my first con on the metco breather yesterday.
I jumped on it cruising around and i started smelling something bad. The breather isnt very well mounted into the billet oil filler adapter and really doesnt take much to come out, mine popped out and landed on the header and melted it
Old Nov 20, 2004 | 07:34 PM
pdd's Avatar
pdd
why do u have to delete the PVC setup?
