True duals+convertible.
Old Nov 18, 2004 | 12:48 AM
a911medic's Avatar
Exclamation True duals+convertible.
Has anybody done true duals on a vert? I'm wanting to get LT's, cats, H pipe, and side exits in front of rear tires....with a muffler in there somewhere. I'm just not sure if the framework is the same on the vert as coupes, and will allow such a thing. HELP!
Old Nov 18, 2004 | 12:55 AM
mnc2886's Avatar
Check out the "boom tube" for something like that. It is on ls1sounds.com. (front page)
Old Nov 18, 2004 | 01:09 AM
Z28Venom's Avatar
Stay away from the boomtubes unless you like to have bleeding ears.
Do a search for side exits. There's a black T/A with a catted true duals setup using sweet thunder mufflers and chrome Z28 tips. The tips exit right in the front of the rear tires.
I believe that if you're going with side exits, the framework is all the same..
Old Nov 18, 2004 | 10:08 AM
Stark's Avatar
Yep, framework is the same. Just be sure and get a tune SOON after your install or the fumes will get to you.
Old Nov 18, 2004 | 11:23 AM
Z28Venom's Avatar
If he's gonna go side exits, I'd think that cats would be a must..
Old Nov 18, 2004 | 11:53 AM
Stark's Avatar
I agree, cats will be needed for a side exit. I'm saving money now to extend my dumps out the back. You were right Z28Venom, the fumes do get to be a annoyance.
Old Nov 18, 2004 | 12:06 PM
a911medic's Avatar
Well my plan is to a similiar setup on that black TA. I will use cats, and probably some magnaflow bullets. and exit the exhaust out the side. Have any of you heard this setup, i want it to sound good, but not be annoyingly loud. How does my vert frame differ from others? Thanks for the inputs.
