GMS MAF & Lean Codes
Old Nov 29, 2004 | 07:59 PM
mike s.'s Avatar
Default GMS MAF & Lean Codes
I recently installed a GMS MAF and now Im getting lean codes on bank 1&2. (P0171&P0174). Is there a viable solution to stop the codes from setting off while using that MAF?
Old Nov 29, 2004 | 08:06 PM
unit213's Avatar
Administrator
Yes, get a tune.
My suggestion is to pull that POS off and put it on Ebay. You're much better off with the stock MAF. There are many other places to look for power.
Old Nov 29, 2004 | 08:22 PM
mike s.'s Avatar
I was afraid of that answer. Any one tune in houston?
Old Nov 29, 2004 | 09:39 PM
DrkPhx's Avatar
Exactly. I had one that caused the same exact codes and also a surging idle. Put a stock descreened MAF which eliminated the problems. I also saw zero gain for hp with it.
Old Dec 1, 2004 | 05:49 AM
Slowhawk's Avatar
LS1Tech Sponsor
Sell the GMS MAF. It is worth nothing but headaches.
Old Dec 1, 2004 | 06:29 AM
y2khawk's Avatar
It'll cost you just as much for the tune as you probably paid for that POS. Sell it and cut your losses
