ah, the age old question...which pulley??
new one from them has no issues with double roller right?
from the reading i see they are good, but if anyone thinks otherwise let me know. which sponsor sells them the cheapest?
I don't think you'll go wrong either way. I'd say stick with either ASP or March.
The March is heavier than the ASP, but on the upside it does dampen better for cars with alot of mods.
haha I don't want to steer you either way because the difference in most cases is probobly minimal. Good luck! My lunch's over.
an underdrive pulley IS a worthy mod as it frees up the crank by minimizing the drag applied on it. asp and march are the two top names that are under $300. next step up is ATI Damper but that is BIG $$$...best in the business tho. personally i'm going with a march fluid dampened pulley when the time comes, i have heard great things about it, nobody has had any issues with knock or belt slippage, and while its about the same weight as stock, the fluid on the inside remains motionless so it shouldn't be calculated as rotating mass.
http://www.thunderracing.com/catalog...vid=3&pcid=111
Looks like a good deal on the march pulleys right now.
