Tension pulley question
Old Dec 8, 2004 | 08:14 PM
Gonzo1's Avatar
Default Tension pulley question
Are there bearings in the pulley to make it have a churping noise? Mine does it when its cold then after it warms up good its fine. If I replace it can I just replace the pulley or is it the whole assembly thats got to be replaced? Is there a how to take off and put on anywhere that I could look at and read? Also this is on a 2000 SS that is bone stock.
Old Dec 8, 2004 | 09:33 PM
WAHUSKER's Avatar
I could just be the belt. You can buy some 'belt dressing' & spray that on to see if it goes away.
But yes, ther are bearings in it. You can buy a pretty replacement from MBA. I think Thunder sells them too. Very easy to replace. Email me & I'll type you up the instructions.
Old Dec 8, 2004 | 09:47 PM
Gonzo1's Avatar
Default Instructions?
Could you please send me instructions?
Old Dec 9, 2004 | 10:47 AM
Z28Venom's Avatar
Instructions..
Remove the belt.
I can't remember if it's a 13mm or 15mm socket to remove the pulley. It basically just screws onto the block.
Takes 5 min to swap out.
Old Dec 10, 2004 | 12:27 PM
Gonzo1's Avatar
Are you talking about the whole assembly or just the pulley? Can I just buy a new pulley and not the whole thing? Does anyone know of any part numbers for just the tensioner pulley ( not the assembly ) for a 2000 SS?
Old Dec 10, 2004 | 06:11 PM
hardtopSS's Avatar
its the whole assembly, the pulley, and the mounting plate. thunder racing sells the adjustable ones
Old Dec 10, 2004 | 06:44 PM
Gonzo1's Avatar
Thanks but trying to find out if I can just replace the pulley without buying the whole assembly. Part numbers would be great if anyone knows what just the pulley part number would be.
Old Dec 12, 2004 | 09:49 PM
Gonzo1's Avatar
Does anyone know?
Old Dec 12, 2004 | 10:35 PM
Another_User's Avatar
Does anyone know?
Yes. The tensioner pulley can be replaced. You can get it for about $10 at autozone. It has the bearing built into the pulley (the pulley is actually plastic). I am not sure if that will solve your chirping problems though.
Old Dec 12, 2004 | 10:37 PM
The idler pulley is Dayco 89007, and the tensioner pulley is Dayco 89015.
Old Dec 13, 2004 | 06:10 PM
Gonzo1's Avatar
Thanks!
