place for oil temp sender???
1) is this true?
2) if so, does the port by any chance fit the autometer sender for an oil temperature gauge???
There is a little place to tap right above the oil filter. Took five mins to pull it out. I drilled it out and tapped it. Just make sure that you use a teflon sealant. I used teflon tape.
Works like a charm.
Works like a charm.
