__________3'' or 2.5'' for Y-pipe?_________
Old Dec 14, 2004 | 04:17 PM
LS1SS4ever's Avatar
Question __________3'' or 2.5'' for Y-pipe?_________
Which one is better for these setup cam, intake, pulley, lid and bolt ons? And for lower car?
Old Dec 14, 2004 | 05:39 PM
LS1LT1's Avatar
Depends on the cam and power output I would think, the 2.5" might still be somewhat restrictive over a 3" if it's a really stout set up.
For a lowered car the 2.5" is always better but of course there is the potential sacrifice of power gains just to have that extra clearance.
Old Dec 14, 2004 | 05:52 PM
LS1SS4ever's Avatar
It's the new one TSP 233/239
Old Dec 14, 2004 | 05:55 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
The critical constriction of any Y-pipe is its Merge collector. Even if you decide to go with 2.5" (2.75" would be better- while 3" best), make sure you use one of these Flowmaster collectors as your merge if you're thinking of making a custom Y, or having one made for you by an exhaust shop:
They come in 2.5" in/ 3" out, 2.5" in/ 3.5" out and 3" in/4" out
I think a 2.5" Y-pipe flowing into a 2.5"/3" Y-Merge should flow decently, considering the rest of your catback will probably be 3".
Old Dec 14, 2004 | 06:01 PM
LS1SS4ever's Avatar
Where can I buy 2.75 Y-pipe?
Old Dec 14, 2004 | 08:46 PM
LS1LT1's Avatar
Not sure if anyone actually makes one but a muffler shop might be able to fabricate one.
Look at the QTP Y pipes as well, they come with the above mentioned Flowmaster merge collector.
Old Dec 15, 2004 | 04:43 AM
LS1SS4ever's Avatar
I thing I will go to 2.5 because I will lower the car. Am I going wrong?
Old Dec 18, 2004 | 05:36 PM
racrx's Avatar
2.5" is fine.
Old Dec 18, 2004 | 07:29 PM
Fulton 1's Avatar
Unless you're going to run a 4" I-pipe I'm not sure there'll be a benefit to a 3" Y-pipe. Now if you were talking true duals then IMO 3" is the way to go. Either way, if you do go for 3" (actually this is probably applicable to 2.5" as well) strongly consider using one of the Dr. Gas clearance tubes just behind the collector on the driver's side. You'll be surprised how much ground clearance you'll gain by doing this.
link: http://www.drgas.com/product.asp?id=10
Old Dec 18, 2004 | 10:00 PM
matts22's Avatar
The point mentioned above is the one that I think needs clarified. What is the point of a 3" y-pipe only to restrict it to a 3" catback?
My thinking is this: As gases cool, they will compress, meaning that you will get the same flow out of smaller pipes. I wish that it was proven that this happens in this situation though. I think the ideal situation would be to have a 2.5" y-pipe with a 2.5in/3"out merge collector going to the 3" catback. Because two 2.5" pipes outflow one 3" pipe. Anyone care to comment on this?
