What does your March pulley look like?
![Lightbulb](https://ls1tech.com/forums/images/icons/icon3.gif)
Originally Posted by M6HuggerSS
so it sounds to me like if you want some added insurance to help the longevitty of your
motor you should get a MARCH ....
but if you are just looking for an extra 10hp and possibly harming your crank , get the ASP. which has NO extra dampning...
FWIW, when I ordered my March pulley, I asked a guy at Thunder Racing about any difference in power between the ASP and March setups. He said the March made more power on the dyno, if I remember, 1-2 hp. I didn't get into the details, but it was a back-to-back run on his own car.
Chris
Chris
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Originally Posted by DMNSPD
Different cars, different dynos, different days.
Impossible to say which one is better. FWIW, I'm only going with the March because I can get it really cheap - otherwise I'd go with the ASP.
and no an ASP will not see anywhere near a 10hp increase over a March either.
i didnt know that the MARCH made HP over the stock... i thought it was just for more dampning!
Gotta remember guys that the increase in HP isn't because the pulley weighs less. The increase comes from underdriving the accessories like Power steering, Water pump, alternator and AC. If they aren't spinning so fast they don't use as much HP.
A smaller lighter pulley will help the motor itself spin up faster like a light weight flywheel but won't add much HP.
Cheers
Mike
Cheers
Mike
Cheers
Mike
Cheers
Mike
Almost like saying the lighter pulley requires more omph to keep it spinning at higher revolutions, whereas the heavier pulley might take more omph to get it going on the low end, but it's momentum keeps it going on the top end. Maybe that doesn't make sense
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Very good point.
Almost like saying the lighter pulley requires more omph to keep it spinning at higher revolutions, whereas the heavier pulley might take more omph to get it going on the low end, but it's momentum keeps it going on the top end. Maybe that doesn't make sense![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
The HP gain from most of these pulleys is that the overall diameter is smaller than the original. Therefore the engine accessories aren't being spun as fast and using as much power. It's just gearing everything down a bit.
The other area where they might gain you some HP is that they can more effectively damp out power robbing vibration in your rotating assembly.
Cheers
#32
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#33
Cheers
Cheers
Less weight equals better et every time without a doubt!
