Banging issue with MACs
Old Dec 22, 2004 | 09:58 PM
locosteelersfan's Avatar
Default Banging issue with MACs
Midlength guys, are you having any rattling and banging
like that associated with alot of LTs?
What setup are you running behind the Macs(which Y+cats)
I have a 1" drop on mine so I'm looking to avoid as much scraping
and banging as possible.
THANKS
Old Dec 22, 2004 | 10:15 PM
Ferocity02's Avatar
I had MACs and no problems with scraping or banging. I used the MAC y-pipe with bullet mufflers instead of cats and it worked great. I highly suggest them. If you want to run a catted y-pipe I suggest getting a MAC ORY then buy some Carsound cats and have them welded in.
Fast Eddie's 02 T/A vert.'s Avatar
I have the Mac headers,cats and y-pipe that I bought as a set. The shop I took my T/A to had no problems installing the header set whatsoever. I have no issues with banging or any issues with fitment. My T/A is lowered 1.25 in.
I am very happy with the whole situation.Great improvement power wise too.
Old Dec 22, 2004 | 10:17 PM
AnthonyR's Avatar
If you have MAC's with EGR and AIR provisions they have been known to cause a rattle type noise under the hood. The EGR tube on the passenger side will sometimes rattle against the header (happend to me). Also the y pipe has been known to bang the floor under acceleration, just have to adjust on it until you get it not to bang.
Old Dec 23, 2004 | 08:33 PM
WILWAXU's Avatar
There is a ton of adjust with a MAC y-pipe. Need to tinker with it till you get it in the right position.
Old Dec 23, 2004 | 09:09 PM
John_D.'s Avatar
I have a used set of MAC's and catted y-pipe on mine.
Eibach prokit springs.
No rattles or bumps.
It wasn't hard to adjust at all. I also have poly mounts which cuts down on movement, and a bmr k-member which aids in clearance around the k-member.
Old Dec 23, 2004 | 09:29 PM
LS1_PNYTAMR's Avatar
my y pipe bangs the underneath of the car a bit but i just put them on and can prolly fix the problem with ease. they were simple to install and feel good i know that much.
Old Dec 23, 2004 | 10:26 PM
Mike98WS6's Avatar
I have the MAC set up. No problems here.
Old Dec 24, 2004 | 12:37 AM
00Z-28Maro's Avatar
My Mac ORY used to bang the first time I installed it, but I took it completely apart (breaks down to 2 peices) and when I put it back on the car I left the bolts that hold the 2 peices loose till I had everything else tight then adjusted them and tightened them down, no more banging.
