ls6 intake question
Old Dec 29, 2004 | 09:13 PM
blu98ta's Avatar
Default ls6 intake question
Will anything bad happen if I put on my ls6 intake without getting it tuned right away with my mods. I am going to buy a ported tb, but i think I am going to do some racing before the tb comes in, so i thought I would at least put on the intake. What, if anything, bad will happen if i dont get it tuned?
Old Dec 29, 2004 | 09:14 PM
nikon1999's Avatar
if your removing the egr and air then those codes should be deleted, its recommended you dont do full throttle passes with those codes on (ses light from it) Other than that your af will be off a little. If your air and egr is already deleted then i wouldnt sweat it at all.
Old Dec 29, 2004 | 09:18 PM
blu98ta's Avatar
ya the air and egr are already deleted. So nothing bad will happen? I don't want to do this and then regret it later.
Old Dec 29, 2004 | 11:08 PM
00ls1's Avatar
Possible Scammer - Buyer Beware - Issues Unresolved
i got mine put on 3 months ago, drives fine un-tuned. why do oyu say no full throttle passes?
Old Dec 29, 2004 | 11:32 PM
nick3205's Avatar
You wont need a tune.
Old Dec 29, 2004 | 11:40 PM
Dustin 98TA's Avatar
I put mine on and im still untuned for a bit longer, no problems here but a check engine light.
Old Dec 30, 2004 | 01:25 AM
blu98ta's Avatar
Is the check engine light because the egr is not being used and has not been deleted? Ya and why are some people saying no full throttle passes?
Old Dec 30, 2004 | 02:08 AM
LS1LT1's Avatar
Question
why do you say no full throttle passes?
Yeah I'd like to know as well...I thought merely turning the codes off (via Edit/Predator etc.) changes nothing but the actual light on the dash, the car should function/run the exact same way as before turning off the SES light which in and of itself might not be ideal until it gets properly tuned of course. At that point it should run even better yet.
I just put my LS6 intake (and ASP pulley) on on Monday and deleted EGR and AIR as well, I have the dash light as expected but I plan on racing the car in just over a week and setting a new best in the process hopefully.
Old Dec 30, 2004 | 02:29 AM
Yea im still on stock tune, I havent deleted anything yet. Im changing my exhaust next week, then I will go in for a tune.
