Low Oil Pressure???Help!!!
Old 01-04-2005, 08:06 PM
ls1fbod's Avatar
Default Low Oil Pressure???Help!!!
Pretty much a shop has put my motor back in with mid's and ory. I origanally had it pulled so i can put a new crank, pistons, and ect...in it. So anyways we started her up to today to brake her in and the oil press is barley a 1/4 over (20-25). And it wont go any higher..Sometimes it sat on 0..What could this be? The oil pressure regulator? Any thoughts?
Old 01-04-2005, 08:13 PM
8-Pack's Avatar
Since the motor just got pulled might be a bent or broken sending unit, located on the back of the intake. 12559781 is for 1998 applications only. 12562267 is for use on 1999-02 applications.
Old 01-04-2005, 08:17 PM
ls1fbod's Avatar
Yeah the mechanic was looking back there for something, but i did'nt know what...And i guess there going to see what it is tomorrow...
Old 01-05-2005, 12:10 AM
ls1fbod's Avatar
Anyone else???
Old 01-05-2005, 12:15 AM
93octane's Avatar
It's either the sending unit on the back of the intake, or the oil pump. If the o-ring on the pickup tube isn't seated properly, that can also give you low pressure.
Old 01-05-2005, 12:50 AM
ls1fbod's Avatar
Anybody else? Im kinda in a scramble for answers in a short amount of time!!!!
Old 01-05-2005, 10:49 AM
LS1TECH Sponsor
Steve Burger's Avatar
Check the O ring on the pickup tube to see if it is torn. This could cause the drop in pressure. Is this a new pump?
Old 01-05-2005, 10:50 AM
ls1fbod's Avatar
yeah it's a new pump
