horsepower question?
Old Jan 5, 2005 | 02:37 PM
ncd1966's Avatar
Default horsepower question?
if anyone knows how much horsepower can you get from doing the egr mod and coolant by pass mod?
Old Jan 5, 2005 | 04:48 PM
Wnts2Go10O's Avatar
for the bypass id say no more than 5 for the egr... prolly around the same.
Old Jan 5, 2005 | 05:10 PM
Dustin 98TA's Avatar
I would say maybe 5 for both, Its one of those "every little thing helps" mods.
Old Jan 5, 2005 | 06:27 PM
Z28Venom's Avatar
Both mods combined, might yield 5HP total.
Old Jan 5, 2005 | 06:55 PM
Humming Bird's Avatar
hey i had a lsx intake manifold and 90mm TB, 85mm mass air flow sensor, long tubes, cattless y-pipe and cat back, as well as a custom tune and my car picked up 17hp 13ft/lbs from the egr and throttle coolant bypass. maybe you pick up more power the more mods you have done to your car. you know, cuz then be come more apparent restrictions to power after your car is breathing better. but im not sure so if anyone knows and im wrong then i apoligize. but ya my z28 picked up alot more power than 5hp.
Old Jan 6, 2005 | 10:21 AM
-Q-'s Avatar
-Q-
Damn, I really need to do that mod then!
Old Jan 6, 2005 | 12:02 PM
LS1LT1's Avatar
Question
Wouldn't the EGR mod already have been done if you had a FAST 90mm combo? And for that matter wouldn't the throttle body bypass have automatically been done as well considering that most 90mm TBs don't have the coolant tubes running through them?
When we say 'EGR mod' we are talking about the simple 'cutting of the protrusion' that invades the hole on top of the intake on pre 2001 LS1 F-bodies correct?
Or do you mean total removal of the EGR system?
Old Jan 6, 2005 | 06:30 PM
Flawless02SS's Avatar
yeah i'd say 5-7hp with both
 Michael S. Palmer
Old Jan 6, 2005 | 06:44 PM
the removal of all of it. did he mean just cutting down the egr? i was confused sorry. ya i meant removing the whole system and doing the bypass, oh and my 90mm TB did have a coolant line
Old Jan 6, 2005 | 07:26 PM
-Q-'s Avatar
-Q-
What do you guys think just the throttlebody bypass mod is worth? 2-3 hp?
Old Jan 6, 2005 | 07:46 PM
cyphur's Avatar
MAYBE, if you're lucky.
Old Jan 7, 2005 | 08:55 AM
-Q-'s Avatar
-Q-
I'll probably do it anyway, just for the hell of it.
Old Jan 21, 2005 | 06:26 AM
ricekillman's Avatar
The difference will be so insignifican that you will not see it on the dyno. The difference between pull one and pull 2 and three will be more then what you gain.
