EGR Removal
Old Jan 11, 2005 | 10:43 PM
A-Bomb's Avatar
will it still throw codes even if the car is tuned?
Old Jan 12, 2005 | 12:03 AM
psykoTA's Avatar
Do any of you guys that have removed the EGR system, have any of you had problems with pinging?
Old Jan 12, 2005 | 12:20 AM
Tripdagoat's Avatar
Default Egr Or No Egr
Was wondering what if any horsepower difference there is between the non egr vette ls6 intake and the Slp egr ls6 intake? I have a 2000 Trans am, i could delete the egr, but if the difference is small enough its just easier to use the slp.
Old Jan 12, 2005 | 08:45 AM
98 Camaro Z's Avatar
I figured it would throw codes but I've had mine reprogrammed so now I'm good to go. The intake was nasty though, need to clean it out now.
Old Jan 12, 2005 | 08:50 AM
foff667's Avatar
LS1TECH Sponsor
its probably minimal but it sure cleans up the engine bay and saves a handful of weight off the front end of the car.
foff667's Avatar
LS1TECH Sponsor
yes, there have been some.
Old Jan 12, 2005 | 08:51 AM
foff667's Avatar
LS1TECH Sponsor
if its tuned correctly no.
Old Jan 12, 2005 | 09:56 AM
psykoTA's Avatar
How did they fix that? A tune?
Old Jan 12, 2005 | 09:59 AM
foff667's Avatar
LS1TECH Sponsor
yeah.
Old Jan 12, 2005 | 07:24 PM
Another_User's Avatar
Originally Posted by 5POINT7
It doesn't add any power. It's for weight (very little at that) and it really just cleans up the engine bay.
I disagree. I think it adds power on cammed cars, at least if you have one with a lot of overlap. The cam causes dilution of the mixture, adding in EGR on top of it may dilute the mixture too much. It may sound like BS, but I felt a difference. And I was not expecting to.
Old Jan 12, 2005 | 08:15 PM
A-Bomb's Avatar
what do you do with the wires that go to the EGR after you remove it? trace them back to the computer and cut them off or what?
Old Jan 14, 2005 | 06:06 PM
  #32
WILWAXU's Avatar
Most just zip tie them out of the way.
Old Jan 14, 2005 | 06:09 PM
  #33
NOTFAST's Avatar
let them hang
Old Jan 14, 2005 | 06:53 PM
  #34
Goodness, don't cut them off! If you ever have to put it back on, you will be in for a ton of trouble. Wrap electrical tape around the plug end and tape and/or zip tie it to the closest part of the wiring harness on the engine.
Old Jan 14, 2005 | 07:51 PM
  #35
A-Bomb's Avatar
lol.....thanks for the input fellas. i guess i'll be yanking this stuff tomorrow....
Old Jan 14, 2005 | 08:07 PM
  #36
JEB99TA's Avatar
... make sure you pull the two A.I.R. fuses so that thing is dead and doesn't blow hot air under your hood.
Old Jan 18, 2005 | 01:50 AM
  #37
Manoso's Avatar
would deleting the egr or air cause problems come smog time? this includes the visual too.
Old Jan 18, 2005 | 05:04 AM
  #38
JEB99TA's Avatar
You'll have stronger carbon emmissions coming out your tailpipes. This, alone, won't cause you to fail emissions testing, IMHO. However, it threw codes on my car immediately, so, if you go with a bigger cam, it would increase the potential to fail testing.
As for the wires? I used clear duct tape to seal the connector's and did what WILWAXU said ... zip-tied the wires out of the way.
Old Jan 26, 2005 | 12:48 PM
  #39
98formulaMAH's Avatar
I know what the EGR tube is, but what are you referring to when you say "A.I.R."?
Old Jan 26, 2005 | 12:54 PM
  #40
A-Bomb's Avatar
PM headed your way.
