EGR Removal
Old Jan 26, 2005 | 01:02 PM
  #41
98 Camaro Z's Avatar
Air pump man! Its down in the LF section of the nose.
Old Jan 26, 2005 | 01:04 PM
  #42
SINISTER's Avatar
Originally Posted by ddelallata
I'm doing it as soon as I get my block off plates for the EGR and AIR that I ordered today. Now that I'll have some room on the front of the passenger side head I'm going to order an AMW catch can as well.
if you know how to weld
a quater and a dime works perfectly to cover those holes not saying that i welded federal money but if one where to need to cover them they would work
Old Jan 26, 2005 | 01:13 PM
  #43
Phoenix 5.7's Avatar
i know when i changed my TB, the stock one was covered in carbon. im deleting egr when i put my FAST in. The whole idea of EGR is rediculus to me. im also geting rid of AIR when i get race headers with ORY
Old Feb 14, 2005 | 07:42 PM
  #44
72short_cut's Avatar
your saying that you dont need to run the egr. but what about if you drive it in the winter?isnt the egr to warm up the intake manifold in cold weather conditions, do i still need to run it. sometimes up here in canada it gets to be -20 degrees celcius.
Old Feb 14, 2005 | 07:54 PM
  #45
no EGR is to reduce emmissions, pure and simple. AIR is to help the cats on a cold start.
Old Feb 14, 2005 | 08:18 PM
  #46
what do you mean by AIR.
Old Feb 14, 2005 | 08:32 PM
  #47
ddelallata's Avatar
AIR. Air Injection Reaction. It pumps fresh air into the exhaust manifolds for a few minutes after start up and then shuts off.
Old Feb 15, 2005 | 12:49 AM
  #48
AllThrottle4U's Avatar
Just to let you know, if you are getting midrange knock before you remove the EGR, you will only amplify it after removal or induce it alltogether. There are more aggresive timing tables when the egr is active. Mainly because it's pumping a spent gas into the chamber that dilutes the ideal combustion mix. Make sure you keep your chambers clean(seafoam), use good gas, ect.... Or you can get a tune and delete the table and codes.
Old Mar 10, 2010 | 03:54 PM
  #49
billy.johnson's Avatar
If you do remove the egr you have to have some kind of catch can right ?????????????
