Denatured Alcohol for Smog
He has an LS1...BONE stock except for EGR removal.
It cleans up the carbon in the combustion chambers and piston tops well also.
FWIW, I started using 'Champion Brands' fuel system cleaner about 5 months ago and use it about every 5th tank full and picked up 1 mpg.
Good luck with the smog test!
Do that first, to make sure the car passes otherwise it might get flagged even if you pass the later on.
Have you got catalytic convertors on? Make sure they are well heated prior to test.
Do you have PCM S/W? If yes, you can lower the O2 switch points a little to help out.
Why do you have to drive so far? Probably found a place that will overlook the longtubes. If you do a pre test at a local shop, that will give you a very good indicator if they visually inspect the LT.
PS I worked in Auburn for about 1 1/2 months last summer. Nice place.
I will probably throw in 2 gallons of denatured with a full tank of gas. I don't mind if performance will go down. Also, I am going to do a pre-test and if it fails I will probably have to tune it really lean to pass.
Also, what exactly should I buy to put in? Denatured alcohol, ethanol, etc... Brands?
What ever "wally world" has. Remember, packaged denatured alky is only 70-80% but no matter.
IF you can find ethanol or methanol, they are more likely to be 99% but may cost more.
2 gals of denatured alky @ .50 a pint is gonna cost $8.00.
2 gal of ethanol/methanol @ 2.50 a gallon will cost you $5.00!
