Service Engine Light On: P0125
Old Jan 11, 2005 | 07:47 PM
'Trust''s Avatar
Default Service Engine Light On: P0125
I had my service engine light come on with a code for bank 1 on my cats, temprature code. I dont have cats, so will i need to replace my front O2 sensors, what could have caused it, any suggestions? TIA
Old Jan 11, 2005 | 08:23 PM
B-MAN's Avatar
Usually,cleaning them will give you about a week or so, replacing them will give bit longer. Your best bet is deleting them with LS1 edit programing.
Old Jan 11, 2005 | 09:30 PM
'Trust''s Avatar
well i have no cats, and O2 sims on the back, wont just deleting them put the car into loop?
Old Jan 11, 2005 | 09:57 PM
ZR2877's Avatar
Maybe the o2 extention got burnt by the header.
Old Jan 11, 2005 | 10:01 PM
ss rally red's Avatar
Damn wish I had Alldata at home but unless you have a heater circuit problem or slow switching your cats or rear 02's aren't your problem. If you have headers that is what is causing your problem,delete your code and see if it comes back.
Old Jan 12, 2005 | 02:30 PM
'Trust''s Avatar
no headers, what is/ or could cause a heater circuit problem? or slow switching?
Old Jan 13, 2005 | 10:17 AM
99FormulaM6's Avatar
P0125 Engine Coolant Temperature [ECT] Excessive Time To Closed Loop Fuel Control
has it been realy cold outside? i threw a code when it was real cold outside when i went to the mall one day. it was probably because of the lt's and extreme temp outside that kept the o2's from heating up when they were supposed to.
why do you have sims out back?
