best sealing exhaust clamps
Old 01-16-2005 | 11:00 AM
SRM's Avatar
SRM
Originally Posted by Tim @ EADPerformance
A good quality v-band clamp will seal excellent. Almost every turbo system has v-band clamps in it, but they are expensive.
A good quality stainless steel band clamp is also great and a lot cheaper. They are meant for slip fit connection, NOT for butting two pipes together. Every band clamp I have ever used has big warnings on it to not use them to butt pipes together.
A quality band clamp will also form aka 'stretch' to the pipes. I always line mine in copper rtv and never had a problem with a band clamp leaking. I just put them on with a impact until it stops and it's good to go.
I dunno. Summit has various types of band clamps - one specifically for butting 2 pipes together.
Old 01-16-2005 | 01:07 PM
Time2Kill's Avatar
MASS seller approved
I just took a look on Summit and found the butt-joint clamps. Those are the exact clamps we use at the shop all the time. There is no way in hell I would trust those to hold two pipes butted together. Kinda ironic when I get them they have big warnings all over the packaging not to use them for a butt joint.
Old 01-16-2005 | 02:10 PM
SRM's Avatar
SRM
I'm currently using that style (napa brand) to butt joints together until I have a chance to have the system welded. So far I haven't had any problems and everything is still solid. Frankly, I'm surprised, but its working so far.
Old 01-16-2005 | 04:18 PM
Full-Force's Avatar
Yes I have used my impact gun on it. I have 4 of them. A 3/8 drive with 75 lb/ft, and three 1/2" drives ranging from 240 lb/ft to 625 lb/ft. There is no making the clamp close up around the smaller pipe (the header in my case) with the clap going over a much larger flare.
Old 01-17-2005 | 12:26 AM
Mike94ZLT1's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...category=33742
Thats a big clamp though, I wonder if you would lose any clearance?
Old 01-17-2005 | 12:45 AM
RPM WS6's Avatar
LS1Tech Administrator
Would that work well on a slip fit connection? Seems like that is more of a replacement for flanges when working with two pipes of the same diameter where neither is flared.
Basically I think band clamps generally only work well when you're sealing very snug fitting slip fit pipes together. If you're dealing with a slip fit where one pipe is able to move easily around inside the other, a band clamp is usually going to leak.
Old 01-17-2005 | 01:28 AM
BLASTER's Avatar
I use these on my exhaust and they seem fine. I have all slip fit junctions.
http://www.jegs.com/cgi-bin/ncommerc...16&prmenbr=361
I use my impact wrench to get them on/off but I actually whip out the torque wrench to give them 75 -80 ft/lbs. I actually can tighten it considerably more by hand but the impact help get everything up and tight enough real quick.
One thing that conserns me is that some of my slip fit junctions are not as snug ans I would like. How do you know if it is leaking? By feel or sound? I may use the RTV like someone suggested just to make sure.
Old 01-17-2005 | 12:02 PM
86 IROC's Avatar
I use those exact clamps on my car, they leak at the y-pipe to header connection. I have coated Pacesetters w/ a QTP ORY. I may try to loosen the clamps and add some copper RTV as mentioned in this thread.
Old 11-19-2005 | 02:51 AM
96silverram's Avatar
Thanks for the pic, I've been looking for that lap clamp.
