lifespan of tr55
Old Jan 19, 2005 | 11:56 AM
warmadness's Avatar
Default lifespan of tr55
whats the avg.lifespan{miles} of the ngk tr55 plugs .same with the msd wires thanx
Old Jan 19, 2005 | 01:42 PM
GuitsBoy's Avatar
Plugs: Check a couple of the easier ones to take out. If they look bad, change them. Id start checking around 20k - 25k.
Wires: Drive them and dont think about it till they start to give you problems (if they ever do)
Old Jan 19, 2005 | 05:58 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Thumbs up
Exactly.
Old Jan 19, 2005 | 06:09 PM
01TAFlyer's Avatar
Not trying to hijack your thread, but what are the effects of over or under gapping a spark plug. Say .50 or .60 instead of .55.
Old Jan 19, 2005 | 07:28 PM
GuitsBoy's Avatar
Its will probably preignite your cylinder and sent the flame front up the intake valve and runner and eventually through the fuel line resulting in the explosion of your fuel tank. Or it could just do nothing. Unless youre running nitrous, FI, or serious compression, dont worry about a little vartiation from intended gap. It will happen over time anyway.
Old Jan 20, 2005 | 02:27 AM
LS1LT1's Avatar
Lightbulb
I just swapped my TR55s out yesterday to try the new Brisk plugs.
My TR55s had only about 2k-3k miles on them and were in the car for over 15 months, they still looked great. Some say to change them after only 10k-15k miles but I'd think you could get up to 25k miles out of them easy in an NA application if the car is tuned properly.
Old Jan 20, 2005 | 05:12 AM
Blacker's Avatar
I changed mine every 20K miles.
Old Jan 20, 2005 | 06:44 AM
RPM WS6's Avatar
I've seen TR55s look fine after 30K miles in a stock motor. Probably a good idea to start checking them after 20-25K though.
Old Jan 20, 2005 | 01:23 PM
warmadness's Avatar
thanx all, had mine in for 33k mit go take a look at them
