ordering mods tonight Suggestion wanted
Old Jan 27, 2005 | 11:28 AM
NY01ws6's Avatar
Default ordering mods tonight Suggestion wanted
2001 ws6 Im going to try one more time tonight if i get some good input i want to order some stuff tonight all i have is a chip hypertech, and a K&n, flowmaster as far as engine mods i want to order tonight need suggestions keep in mind the car is lowered with eibach sportline springs so ther are things that wont work because of ground clearence
car is auto and a street car i drive on the weekends i never took it to the track so keep that in mind i still want to drive it on the street
throttle body?
headers?
y-pipe?
catback?
mass air?
air lids?
any other good stuff?
convertor?
and if any of this stuff is not worth it please let me know
thanks for all your help
Old Jan 27, 2005 | 11:43 AM
mosls1's Avatar
id go with a 80mm BBK if the your not going to go far on mods to the motor.
Old Jan 27, 2005 | 11:45 AM
NOBR8KSS's Avatar
Lid - any brand, they are all pretty much the same - I like MTI
Headers - stainless steel Kooks or QTP longtubes with an off-road y-pipe
Catback - try www.ls1sounds.com to see which one you like
Torque Converter - I hear they are a great mod, but I have an M6 and don't know jack about converters
Throttle body would be a good mod once you start doing significant power adders.
I wouldn't mess with the stock MAF at all.
I would scrap the Hypertech Power Programmer...they only work with a stock vehicle and even then they only work some of the time.
Old Jan 27, 2005 | 11:46 AM
NOBR8KSS's Avatar
Just a thought on this....the BBK is about $300. You could get a ported stock throttle body that works just as well for half that price.
Old Jan 27, 2005 | 12:55 PM
OnE Ls1 2 HaTe's Avatar
ported throttle body, lid and if u got the money get a cat back before you get headers. also you should de screen your maf.
Old Jan 27, 2005 | 01:20 PM
abadss's Avatar
how much you going to spend? here's what i would plan on doing, if not today, then over the next little while.
1. lid-anyone will do
2. headers- you may want to go with Macs since you have sportlines, or kooks, pacesetter
3. off road y-pipe - unless you have emissions, then get one with carsound, random tech high flow cats
4. convertor - something in the 3200 range is very streetable, and will give you great gains
5. fast toys ram air - great mod for the money
6. ASP crank pulley - ditto
7. Cam, valvetrain - when you decide to make some good power
8. cat back - i would ditch the slowmaster and get a decent cat back like borla, CMMG, corsa, or true duals.
also, i would lose the hypertech, its not doing you any good unless you're just using it to change some settings like fan temps, shift points, etc.. the tune is junk. good luck and let us know what you decide.
Old Jan 27, 2005 | 01:23 PM
abadss's Avatar
oh, and i wouldnt mess with the MAF. The TB will be fine until you get a cam, then just get one that has been ported, dont waste your money on a BBK or something of that sort.
Old Jan 27, 2005 | 07:45 PM
NY01ws6's Avatar
thanks for the info!
Old Jan 27, 2005 | 07:52 PM
NY01ws6's Avatar
I got a crap hypertech and i never put the 160 t stat in if i get one has any one had a problem with a ses light
Old Jan 27, 2005 | 08:00 PM
Spdmini's Avatar
DO NOT de-screen you stock MAF. you run a high risk of messing up the wires.
1. Converter.. 3500 or bigger.
2. Headers in Stainless
Old Jan 27, 2005 | 08:13 PM
5POINT7's Avatar
Yup, pretty much what everyone else here said. And leave the stock MAF the way it is.
Old Jan 27, 2005 | 08:34 PM
cyphur's Avatar
A4's should NEVER mess with the maf. period.
Old Jan 27, 2005 | 09:58 PM
BuBbABFP's Avatar
So is a Lid same thing as a K&N Fipk??? what kind of HP gains do u get with the lid?
Old Jan 27, 2005 | 10:10 PM
LSUxBlake's Avatar
The lid works well in conjunction with a catback and ported TB. Alltogether, you can expect 15-25rwhp from those 3 mods.
Old Jan 28, 2005 | 03:41 AM
ZR2877's Avatar
I would go with Kook's headers,ASP pulley, True Duals, Lid and a converter.
