ASP Underdrive Pulley Question
Old Jan 29, 2005 | 03:48 PM
Chevy4Life's Avatar
Default ASP Underdrive Pulley Question
i'm looking at buying an ASP pulley but i have a few questions. Will the pulley effect my stock monsoon stereo at all? Also do i need a an overdrive alt pulley? I heard u should get them on A4 cars but not necessary on m6. Just wanted your opinions...
Old Jan 29, 2005 | 04:00 PM
LS2 Pontiac GTO's Avatar
I doubt you'll need the overdrive pulley for the alt with an m6. Also theres tons of threads on this.
Old Jan 29, 2005 | 06:40 PM
Chevy4Life's Avatar
i was more concerned about the stereo...
Old Jan 29, 2005 | 06:43 PM
Nate_Taufer's Avatar
it might weaken a little when at idle with a/c and the lights on but otherwise you should be okay. Just bump your idle up a little with hptuners or a programmer.
Nate
Old Jan 29, 2005 | 06:45 PM
Chevy4Life's Avatar
well i was going to get a cam soon and i was actually going to drop my idle to probably 850rpm....maybe an Underdrive pulley wouldnt be a good choice for me
Old Jan 29, 2005 | 06:46 PM
Blacker's Avatar
I ran the ASP Pulley and had no charging issues. Even with a bigger system, I haven't had any charging issues. Just get the crank pulley and be done with it.
Old Jan 30, 2005 | 02:37 AM
FAST LS1's Avatar
I have only the ASP pulley, no underdrive or overdrive on the alt. and it's been working fine with the stock stereo.
I've notice the headlights will dim now when I first start slipping the clutch and the rpms drop below the normal idle rpm (750) but other than that no charging issues.
Old Jan 31, 2005 | 10:54 AM
Benjamin Russick's Avatar
I have the ASP and a pretty big cam with no issues. Charges fine, AC is fine, PS is fine, etc...
