Mac mid-lengths header install
Old Feb 1, 2005 | 09:48 PM
Frosty's Avatar
Default Mac mid-lengths header install
Ok, the time is near.
Give me a list for everything I might need/want for this header install.
Mac midlengths w/EGR and AIR tubes. ORY pipe
I read that I might not need O2 extensions with these?
Use stock GM gaskets? Copper gaskets? Do I need a gasket for where the ypipe and headers meet? Use stock bolts?
I'm going to delete the rear O2's...what do I do with the connectors? Do I have my tuning guy delete them first or wait until the headers are on? If I wait will the car suffer performance wise until I get it retuned?
Just trying to get an idea on everything I need. Thanks!
Old Feb 1, 2005 | 10:14 PM
8ASTANG's Avatar
Hey Frosty I just finished installing my mac headers and catted y pipe tonight.10 mm gear wrench is a must.the valve cover bolts are 8mm.As for gaskets I just reused my stock ones.My car has 47xxx on it.I did a search and found all the info I needed on the install.the passenger side bolt for the coil pack bracket is probably the hardest to get off.I went for a drive after and there is a very noticeable power difference.My car is an a4 and when I would punch it at 25mph before it didnt break the tires loose,now it does.good luck
Old Feb 2, 2005 | 06:05 AM
Frosty's Avatar
I'm not worried about the bolts and such. My buddy's shop is doing it.
It tried a search but got about 100 threads of nothing specific lol.
Old Feb 2, 2005 | 07:41 AM
superslowjoe's Avatar
You dont need a gasket where the header meets the y-pipe, they have ball flanges, I re-used my stock gaskets when I did my MAC install. I didnt need o2 extensions with the Macs, but I will tell you that MAC y-pipe sucks, just my opinion though. I tucked the up rear o2 wires up and covered them with electrical tape.
I put on Flowtech long tubes and they suck, after I do the merge collector mod on the MAC's they are going back on!
Old Feb 2, 2005 | 10:33 AM
FinalTA's Avatar
Just curious..but what don't you like about the y-pipe? The merge collector? I'm about to make a header purchase myself...
Old Feb 2, 2005 | 03:29 PM
AdamSS's Avatar
I always thought that Y-pipe fits great, plus there is little clearance issues when car is lowered....
I have MACs myself waiting to be put on once it gets warmer
