Egr/Air
Old Feb 2, 2005 | 02:37 PM
LS1ownzYOU's Avatar
Default Egr/Air
If i get kooks race headers (headers w/o EGR and AIR provisions) and put in o2 sims/extentions and get an Ls6 intake manifold with the AIR and EGR blocked off, will i throw a code?
If i get the headers w/ the provisions and 02 sims/extentions and an Ls6 intake w/o the provisions will i throw a code?
tia
Old Feb 2, 2005 | 02:57 PM
kraut187's Avatar
Yes you will get a code from not having the EGR plugged in and you'll need to unplug the AIR pump otherwise it will blow hot air into the engine bay. These codes can be easily tuned out as well as the back o2 sensors all at once.
Old Feb 2, 2005 | 11:51 PM
Jabroni's Avatar
Yes, more so from the EGR than the AIR. Usually, a tuner can shut them off fairly cheaply. Look into it. Or...just deal with the light till you can get it done.
