What bellow to use with 90mm TB???
Old Feb 4, 2005 | 08:53 PM
SDB's Avatar
SDB
Default What bellow to use with 90mm TB???
I heard the SLP smooth bellows won't fit on the 90mm TB, is this true, and if so, what are the guys using that have 90mm TB's?
SDB
Old Feb 4, 2005 | 08:58 PM
LawmanSS's Avatar
I was under the impression that the SLP bellows wouldn't fit, as well...but a member of this site...Cannibal, I think...was able to make his SLP bellows fit. I bought this one:
http://shop.airflowonline.com/Mercha...tegory_Code=HH
...but I'm going to attempt to make my SLP bellows fit first.
Old Feb 5, 2005 | 02:02 AM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
My cheapo, stiff, 1 rib, ebay scam bellows fit fine. I guess my first mod purchased was good for something afterall.
Old Feb 5, 2005 | 04:16 AM
smokin' joe 00 ss's Avatar
[QUOTE=LawmanSS]I was under the impression that the SLP bellows wouldn't fit, as well...but a member of this site...Cannibal, I think...was able to make his SLP bellows fit. I bought this one:
I use this one too, work's great.
Old Feb 5, 2005 | 09:29 AM
Kurtomac's Avatar
which maf do you have and which t-body
Old Feb 5, 2005 | 10:20 AM
LSUxBlake's Avatar
I'm also running the airflow one listed in the link above. Fits great. I'm running SLP 85mm MAF and TPIS 90mm TB.
Old Feb 5, 2005 | 11:53 PM
Abdullah's Avatar
LSUxBlake, is the 85mm MAF a good mod on H/C car? will it need reprogrammimg the PCM on my 2000 M6 Z28?
Old Feb 5, 2005 | 11:59 PM
Crazy Man's Avatar
Put my friends on yesterday with a 4inch pipe coupler ya know the rubber ones that look like bellows 4.95 at lowes lol
Old Feb 6, 2005 | 12:39 AM
LSUxBlake's Avatar
Well, Jason99T/A dyno tested it on his, and said there was only a 1-2 rwhp gain between the stock MAF and the 85mm MAF. The only reason I'm running it is because it makes it much easier to run the 85mm lid that way, being that it has a built in bellow that will fit both the 78 and 85 mm lids. The way I see the 85mm maf is that you're just helping out one area that can be slightly improved, and by the time you have heads and cam "slight" improvements are all you will find left to do. As far as retuning, I don't think its absolutely necessary, but recommended.
