F.A.S.T stuff???
Old Feb 10, 2005 | 06:29 PM
Phoenix 5.7's Avatar
i have one of the new 90mm fast TBs and they did resolve the shaft issue, but i can't tell if the bearing issue has been fixed. if it wasn't for the great price i got, i wouldn't have gotten the fast unit, i would of gone with TPIS
Old Feb 12, 2005 | 07:39 PM
Bill's 02 Z-28 SS's Avatar
Hi Folks
First with all the posting about how bad FAST TB is, I took some pictures of my TB. The unit looks good. They fixed the issue with the throttle being stuck open with a notched shaft keeping the throttle plate connected to the throttle. The issue about the bearing walking out look likes a non issue. The bearing can't move in, no way. Walking out is always possible but not likely. First, the spring will keep in place if it starts to walk out and on the other side you have the TPS will keep it in place - look at the pictures.
Just my two cents
Bill
I tried to upload the pictures but had problems - sorry will try later
Attached Thumbnails F.A.S.T stuff???-img_0390.jpg   F.A.S.T stuff???-img_0391.jpg   F.A.S.T stuff???-img_0395.jpg   F.A.S.T stuff???-img_0397.jpg
Old Feb 12, 2005 | 07:54 PM
LSUxBlake's Avatar
Have you put it on the car yet? I ask because this one didn't stick when in my hand either, but it did when on the car.
Old Feb 12, 2005 | 08:05 PM
See5's Avatar
Any commonly done mods to the 90mm manifold before install?
I am using LS2 TB.
Thanks
Old Feb 13, 2005 | 10:10 AM
Posted the pictures - look above.
Old Feb 13, 2005 | 02:41 PM
LSUxBlake's Avatar
I am using LS2 TB.
Thanks
I had mine port matched by Allan Futral, you can really tell a difference looking at it. If you look at this thread, you can see the pics I posted of my intake ports compared to the stock pic posted later down.
https://ls1tech.com/forums/generation-iii-external-engine/258559-fast-90mm-intake-ports.html
Old Feb 13, 2005 | 04:15 PM
See5's Avatar
https://ls1tech.com/forums/showthread.php?t=258559
That is exactly what I was looking for>Thanks!
Old Feb 13, 2005 | 05:03 PM
HAMRHEAD's Avatar
I just want the **** to fit together. Don't they test that stuff before mass production. Shouldn't have to call. It is pretty apparent it doesn't fit together.
Old Feb 13, 2005 | 06:29 PM
Dustin Butts's Avatar
Originally Posted by Bill's 02 Z-28 SS
Hi Folks
... The issue about the bearing walking out look likes a non issue. The bearing can't move in, no way. Walking out is always possible but not likely. First, the spring will keep in place if it starts to walk out and on the other side you have the TPS will keep it in place - look at the pictures.
Just my two cents
Bill
Well I can assure you I wasn't hallucinating or using any illicit/illegal substances when I pulled my TPS and saw that my bearing had walked out. There is enough room behind the TPS for the bearing to wiggle out and cause play in the shaft. This play causes the throttle blade to bind and occasionally stick open enough to raise the idle. They may have addressed that issue by now also with tighter clearances etc...Keep an eye on it if you ever have idle problems.
I'm not trying to be rude...just stating facts.
Old Feb 13, 2005 | 08:27 PM
LSUxBlake's Avatar
And like I said, my FAST TB didn't stick when I was holding it in my hand either. It did, however, stick after it was installed on the car. At one point, my car had to be shut down as it was stuck at 5000 rpms, and the cable had to be pulled shut by hand. Keep in mind, this is the same "fixed" version you have.
Old Feb 14, 2005 | 09:24 AM
Hi LSUxBlake,
I understand - I plan on using a center punch and stake the bearing so it can not come out. I am sure what you folks are stating is very true but there are way to correct the issues. It appears the factory peens the bearing hole but I make sure it never comes out.
I guess what I am surprised about is the fact that FAST has not tried to address these issues on the threads. Oh well.
Thanks for the heads up.
Bill
