Ticking after Pacesetter Install
BTW, is that exhaust setup raspy, or are you happy with it. Other than the ticking of course.
I think the noise you are hearing is the AIR. I have Pacesetter LTs and haven't had a problem with them. Something you might want to try is to put a small washer inside the AIR (between the Header AIR connection and the AIR connection that ties into the rubber hose). That's probably what your hearing is the check valve fluttering.
Worse case, you have a leak. But I reused my factory gaskets. They work great. So I don't know if that it.
Did you get the ceramic coated Pacesetters? I had Mac midlengths first, and they had a rasp to them and they were uncoated. But after installing my Pacesetters, I never heard the rasp again.
