02 Sim install
Old Feb 7, 2005 | 02:02 PM
Steves01Z28's Avatar
Default 02 Sim install
Sorry to bother with this, but I can't find where to install one of the 02 sims. I got one connected under the brace in the middle-center of the car closer to the right side. Where does the other one go? Is there a site that shows where they attach?
Thanks!
Old Feb 7, 2005 | 02:14 PM
GT Griller's Avatar
Just folow the 02 sensor that u are replacing.
Old Feb 7, 2005 | 02:22 PM
code4's Avatar
Thanks!
My driver side plug was on top of the K member.
Old Feb 7, 2005 | 03:16 PM
I would but they were removed when I got a new cat-back system. So from the 02 under the K-member on the right side, where is the other 02 connector?
Old Feb 7, 2005 | 03:42 PM
code4's Avatar
I'm starting to doubt myself here. My car is on the ground & covered right now. I am almost positive that there is a plug on each side of the tranny (m6) for the rear 02's. They are attached to the tranny, I just filled the plugs with silicone, it's been a while ago. If you don't get an answer I'll put her back on the lift later tonight. I am debating driving her anyway since we are getting some sun right now.
Here is a pic, I believe the blue connector you can see closer to the bell housing is to the driver rear 02. The other connector is the CAGS delete.
Old Feb 8, 2005 | 07:15 AM
Thanks! I am going to try and get it on a lift and see if I can find the other connector. Thanks for the help.
