Rattle from under my car
Today when i started my car i noticed a rattle coming from under my car it kinda sounds like something is loose but it goes away when i drive or maybe cant hear it but it it seems to go away for a while and comes back should i worry.
I have found an assortment of spots the exhaust can rattle.
1) O2 sensors loose (rare)
2) Y-pipe hitting under car
3) aftermarket exhaust hanger hitting heat shield on gas tank
4) vibration causing metal exhaust hanger to move back and forth through the rubber exhaust hangers (weird one, but this is what has been happening on mine)
5) exhaust resonance vibrating heat shield on gas tank
I am sure there are plenty of other places rattles could come from, but those are my favorites.
LS1Tech Administrator
Received 1,692 Likes
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Honestly, there are about 100 spots that could be rattling to fit your description, some of them not even exhaust related (I found one of my rattles to be a fuel line vibrating aganist a heat sheild). You'd need to at least pinpoint the general area (front, back, middle, driver's, passenger's, etc.) before going any further.....
It's coming from the front of the car near my transmission.
I was under my car today and the rattle isn't coming from my heat shields i cant figure out where its coming from. It sounds like someone kicking a can with a marble inside of it.
Try this: once the exhaust is cool to the touch, trying getting under the car and banging on the I-pipe and Y-pipe with your hand. Do you hear the same sound when doing this as when the car is idling? That's how mine was, and it was the rear O2s.....
Could it be my cats going bad.
I dont know if this matters but there is ash coming out of the exhaust not alot but some.
Again, try hitting them with a mallet and see if anything inside is loose/bouncing around. Should be fairly easy to tell.......
