im waiting for spring and im bored
Old Feb 9, 2005 | 07:36 PM
badaSS346's Avatar
Default im waiting for spring and im bored
Well spring is right around the corner and i was looking at the car today thinking what can i do to it. Well i have an idea. Not the best thing but its different. In the grill section of our noses there are those 2 holes that do absolute dick but look aggressive. what about this....cut away the foam from the bumber support. Drill a same size hole in the frame section, then cutout some pastic and make a path from the nose to the bottom of the air lid...picture the ssra kit going to the nose instead of under the car. I know its not the greatest idea but, im bored and got a really big drill in the garage that i wanna use. Someone remind what a dumb idea this is before i hack up this poor car!
Old Feb 9, 2005 | 08:48 PM
5POINT7's Avatar
It's a dumb idea. Go play Need for Speed underground or GT3 and you'll be fine.
Old Feb 9, 2005 | 09:00 PM
badaSS346's Avatar
here is the thing...the ssra or the ftra both block off part of the radiator, so not as much air can go thru it, hense warmer water temp. I know that the FRA i have is garbage and want to either make it stock or come up with something to make it better. I actually took my idea off the C5-R. Got to see one the other day and figured if it works for this...itll work for my car.
Old Feb 9, 2005 | 09:23 PM
ramairJP's Avatar
you mean like this:
http://www.ls1.com/link_cold_air_mod.htm
Old Feb 10, 2005 | 08:36 AM
badaSS346's Avatar
Originally Posted by ramairJP
No, that will not make any real difference. What i want to is cut out the entire square hole....not that pre cut circle and make it go to the bottom of the lid...just like the SSRA or FTRA.
