coil packs
Old Feb 11, 2005 | 03:27 PM
GET_SOM's Avatar
Default coil packs
whats the order that the coil packs should be in on a 98?
Old Feb 11, 2005 | 06:13 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
What do you mean "order"? Each coil goes directly above the plug that it will be firing......
Old Feb 11, 2005 | 06:41 PM
jrp's Avatar
jrp
SN95 Director
i think he means what order do they go in if you take them off and want to put them back on.
there's no way you can really screw it up, just line the bracket holes with the ones on the valve covers. coil packs arent bank specfic either.
Old Feb 11, 2005 | 06:43 PM
GET_SOM's Avatar
like the wiring harness that plugs into each individual coil pack, theyre labeled with 1/8, 3/6, 5/4, 7/2....theyre supposed to go in a certain sequence, does ne one know the proper order?
Old Feb 11, 2005 | 06:53 PM
jrp's Avatar
jrp
SN95 Director
are you sure your not confusing the coil pack harness with the fue injector sensors?
Old Feb 11, 2005 | 07:15 PM
y2khawk's Avatar
front to back...
driver side, 1-3-5-7
pass side, 2-4-6-8
Old Feb 11, 2005 | 07:42 PM
GET_SOM's Avatar
so on the passenger side it should go 7/2, 5/4, 3/6, 1/8
and on the driver side 1/8, 3/6, 5/4, 7/2?
Old Feb 12, 2005 | 12:31 AM
y2khawk's Avatar
correct
Old Feb 12, 2005 | 11:42 AM
GET_SOM's Avatar
k, thanks
