*Anybody overheat with there FTRA?*
Once you have all your leaks fixed, go out an drive the car again. I am positive you will notice a significant improvement in performance, throttle response and fuel economy.
And I have never had any heat issues whatsoever.
Heck, If someone has installed this kit on their ride in Kuwait with no issues, then you know you may have problems with your cooling system.
Oh...I'm also down here in Texas.
I have the FTRA and I like it. But I have never seen a lid that isnt going to leak somewhere around the seal. I did the leafblower test and I could feel a little air around where the lid sealed but not around the FRTA seal on the front. Are you telling me that you have done this with a leaf blower and had absolutley no air coming out from anywhere?
Last summer I did turn on my AC and the temps went high instantly, don't know what that's about. (Tune?) But without the AC on, I hover just above 170* with a 160* stat here in hot South Florida.
Also what's this foam stuff??!! I don't recall using any foam. I blocked off the front of the airbox with AC Commercial duct tape (the real shiny one) and I think I'm sealed.
MY K&N gets dirty very quickly. Much more so than when I just had Free Ram Air.
224/.581 isn't that small of a cam. I trapped 118 in the heat with my cam+bolt-on car no ported heads without the ftra.
As a matter of opinion, I still do think the 224/581 is small by today's standards. My fellow club members are running high 230's to 240's with over .600 lift.
Anywho, back to the topic, I think the FTRA is both CAI and a ram air. Tell ya what, I will clean and oil my K&N Friday, and take pics. After 75 miles, I'll retake the pics to show how much air (by dirt marks) this thing is pulling through. With !FRA, I rarely had to clean the filter. This thing HAS to work. Perhaps .5 to 1.0 mph.
how do you know you didn't have a temp increase? you don't b/c you have a dummie temp guage like me. Mine needdle stayed on 210 like normal the whole time. And the car did not over heat, and it was running perfect. Jus the coolant was bubbling. When it gets warm im going to flush the system and put a 160 stat in.
p.s. my car only has 19k miles, alll hoses look brand new. So it jus might be the stat. But i'll check it out
My comment about turning on the A/C was just to trigger the 2nd fan (that happens autotmatically when the a/c comes on). If your temp drops, fan programming will lower your operating temps with the FTRA. As you know, if the cooling system is being pushed, turning on the A/C should really raise your temps.
If your car is actually overheating (for whatever reason), turn your HEATER on HIGH as it acts as a little radiator and may give you enough extra cooling to get you to a shop to check things out.
The temp guage on later model years is not as sensitive because GM customers were freaking out whenever the guage went to 220 which is perfectly normal but caused a lot of service complaints. Like I said before, the 2nd fan isn't even programmed to come on until 220ish.
Get a fan switch or fan programming if you want a little extra cooling. A 160 stat on it's own without fan programming will do nothing.
