How to clean MAF wires?
Old Feb 15, 2005 | 04:55 PM
demonspeed's Avatar
It's not mine! woo hoo!
Default How to clean MAF wires?
What's the best way to clean MAF wires? I was thinking a qtip with some rubbing alcohol. Any better ideas?
Old Feb 15, 2005 | 04:59 PM
silverZ98's Avatar
thats what i did and worked fine jsut be carefull
Old Feb 15, 2005 | 05:51 PM
Another_User's Avatar
Yes. Just little touch the resistors. It won't take any pressure to remove the residue, so do NOT press.
Old Feb 15, 2005 | 08:14 PM
jbuckweiser's Avatar
Are you cleaning wires because of oiling air filter? I got an SES code and I had a can
of Electromotive CRC electrical cleaner and flushed wires and that took care of it.
Old Feb 16, 2005 | 01:17 PM
demonspeed's Avatar
Thanks for the replies. I'm cleaning it because I'm switching from a K&N back to an AC filter.
Old Feb 16, 2005 | 01:24 PM
smokin' joe 00 ss's Avatar
Yea just get some electical contact cleaner in a spray can and you won't have to touch the wire's with a Q-tip, it clean's and dries real fast.
Old Feb 16, 2005 | 02:19 PM
mc01ta's Avatar
i picked up some at radio shack. sparyed on, shook the maf a few times and let it sit to dry. lots of dark grease came of my 01's. cost me $5.95 i think for the can, have plenty left, little bit goes a long way.
Old Feb 17, 2005 | 12:52 AM
BriancWS6's Avatar
I take normal rubbing alcohol that i have in a spray bottle and just spray the stream over the wires. Works good for me.
Old Feb 17, 2005 | 01:30 AM
LSUxBlake's Avatar
Autozone sells electric parts cleaner, works really well and if you put a sheet of white paper under it you'll see all the dirt that comes off. I'd recommend that over using a qtip and making contact.
Old Feb 17, 2005 | 07:48 AM
lastcall190's Avatar
I used carb cleaner when I did the TB, and others. I also used a qtip and be very careful those things are tiny as hell.
-J
Old Feb 17, 2005 | 10:57 AM
demonspeed's Avatar
I used the electrical parts cleaner from CRC. I was pretty suprised how dirty the thing was. I didn't use any qtips or anything. I just sprayed it and it sheeted the grime off and dried in seconds.
So if anyone else has this question, this stuff works.
