pulleys
Old Feb 16, 2005 | 02:00 AM
mean00SS's Avatar
Default pulleys
what does everyone in here recommend when buying a pully, brand?, both underdrive and alternator or what? and are they woth it?
thanks for info in advance
Old Feb 16, 2005 | 02:15 AM
2MuchRiceMakesMeSick's Avatar
LG motorsports uses ASP for their pullys. I have one for sale if you need one. Send a PM or check the sig for details.
Old Feb 16, 2005 | 05:04 AM
ZR2877's Avatar
ASP pulley here. I went with only the crank pulley.
Old Feb 16, 2005 | 10:15 AM
mean00SS's Avatar
does it affect the alternator and all that alot when driving?
Old Feb 16, 2005 | 12:47 PM
Lithium's Avatar
SSU's Drunk Typing Whore
No, while driving everything is normal for me. I got the crank pulley and alternator from ASP. Good product.
Old Feb 16, 2005 | 06:34 PM
ULTIMATEORANGESS's Avatar
crank pulley from ASP is what i went with.good mod for what it cost me.
Old Feb 17, 2005 | 12:27 PM
Ron78Z&01SS's Avatar
The overdrive alternator pulley is just to speed up the alt to prevent any possible charging issues. You should be way good on your SS being that it's an M6 (higher idle speed than auto) as long as you don't have an insane aftermarket stereo I would think.
I've got just the crank pulley on my M6 and the only time I notice my battery lower than normal is if I'm at a stop for a while with the rear window de-frost, head & fog lights and blower motor on high. In fact my 2 previous cars had just the crank pulley (they were both autos...a 95 Z28 & 85 Corvette) and if I sat at a light for a while at night, I would just pop it to neutral to raise the idle.
I decided on the "new" SLP pulley (old one had issues with false knock) on account of the high belt retention walls: http://www.slponline.com/view_produc...1&BIG=100221-1 I read that some cars with weak idle tensioners & 25% U/D pulleys had issues with throwing belts at higher RPM's.
The SLP pulley is made in Australia and is available under the name "Powerbond" I believe. If you see a pic of the Powerbond compare it to the SLP to make sure though.
Do yourself a favor and check the sponsors for the best price. I got mine on sale from T-Byrne with a new bolt & both belts for $210 SHIPPED
Old Feb 17, 2005 | 12:44 PM
LSUxBlake's Avatar
ASP makes a real good pulley. No need for the overdrive alternator pulley unless you are running amps or somethingl ike that.
 Michael S. Palmer
Old Feb 18, 2005 | 01:02 PM
FBDYLVR's Avatar
Now I've also heard that pulleys will help w/ gas mileage. Is this true? Have any of you guys experienced better gas mileage w/ the pulleys?
Old Feb 18, 2005 | 01:17 PM
Not sure if it would be enough to notice, but hypothetically it should. Less parasitic drag on the engine.
Old Feb 19, 2005 | 12:09 AM
Toadman's Avatar
I had a post this past week about the pulleys and stuff. After reading this post I'm confused. Is the crank pulley the same as the underdrive pulley or what? Someone posted that I should buy the underdrive pulley but here it says the crank pulley. I'm totally lost on which one of the ASP pulleys I need?
Old Feb 19, 2005 | 02:48 AM
Yup, we're talking about the same thing. It's a crank underdrive pulley.
Old Feb 19, 2005 | 10:56 AM
blind527's Avatar
i want to get an underdrive pulley for my 97 formula. how easy is this to put on? will there be any problems associated with getting a pulley? i know i'll have to get a shorter belt, but aren't belts expensive?
