new exhaust, pics!
the left pipe doesn't seem like it's in all the way though, i have tried SO hard to get that thing in! the right side hangs PERFECTLY, but the left side hangs a little crooked. the muffler also slants down a little bit, but it is all VERY solid. should i have a shop look at this, or just pound the left tube in with a rubber mallet till it gives?
Bang the left pipe till it gives...maybe put some lube on the connections of that one and then bang it into place.
i was never able to get the left one on all the way in the first place, the over axle pipe and the right pipe were already attached to the muffler
i tried putting wd-40 over the left side, but it only goes to a certain point then it stops. the rubber mallet i have isn't in the greatest condition either
You should have a rubber hanger connecting the right tailpipe to the factory position. Get a large radiator hose clamp (the type that you can use a screwdriver or socket on to close/open it, avail at Autozone / O'Reillys), put it around the rubber hanger, and tighten it up. It'll compress the hanger, therefore pulling your muffler and tailpipe up and making them level with the rest.
the left side doesn't seem to go in all the way, so get it compressed and it will pull together? i will see this
