LS1 Air Pump and EGR valve
Old Feb 24, 2005 | 11:36 AM
wstock1980's Avatar
Question LS1 Air Pump and EGR valve
Does anyone know where I can get a new LS1 air pump and/or EGR valve for a fairly decent price? I think my air pump is going out on me.
Old Feb 24, 2005 | 11:45 AM
ddelallata's Avatar
sent you a Private Message.
Old Feb 24, 2005 | 12:09 PM
Red99TA's Avatar
Just yank the AIR crap out...it doesn't help emissions except for when you first start the car up and the cats are cold.
Old Feb 24, 2005 | 05:08 PM
demonspeed's Avatar
It's not mine! woo hoo!
I'm sure you'd be able to find PLENTY of used ones for very cheap.
Old Feb 24, 2005 | 05:25 PM
CRL 01 SS's Avatar
What year is your car? I just had my car HP Tuned and got all of that crap deleted. I'm going to be taking it off my car this weekend. If you can use it and want it I'll sell it for $10 + shipping.
Old Feb 25, 2005 | 07:33 AM
69_YENKO's Avatar
i'll send you mine cheap, PM me if you want it
Old Feb 25, 2005 | 09:21 AM
wstock1980's Avatar
Ya'll rock.... I already got someone to send me one, but thanx all for the responses. I know that it probably doesn't do all that much for me, but it makes obnoxious noises and I can't stand it so I am just going to replace it.
Old Feb 25, 2005 | 10:07 AM
99Hawk262's Avatar
How do you remove this? What does it look like and where is it? Also, if I just yank it out, do I have to do any tuning? Will it trip a SES light? Thanks for any input.
Old Feb 25, 2005 | 05:28 PM
99Hawk262's Avatar
Any one have any info on this??
Old Feb 25, 2005 | 05:39 PM
69_YENKO's Avatar
the air pump is the thing on the drivers side of the engine compartment just behind the head light, that has the large black tubing going to it. if you remove it you will need to get it turned off in the PCM or it will throw a code(i think). i have yet to remove my pump but it is tuned out because i got race style headers with out the provisions for it to hook up to and it would just be blowing air around under the hood for no reason.
Old Feb 25, 2005 | 05:45 PM
69_YENKO's Avatar
forgot, the pump cant really be seen from above because there is a panle covering it. but you can see about where it is from the hose going through the panle.
Old Feb 25, 2005 | 05:53 PM
TNormZ28's Avatar
The pump is really easy to remove 4 10 mm bolts. You'll have to get them from underneath the car. Just undo your water shield flap on the driver side and pull it out of the way and the pump is right there. Then follow your tubes up into the engine compartment and on the back of the driver side head there is a 15mm holding a bracket to the head (a ratcheting wrench will make this pretty easy) loosen that up and start pulling the tubes out. Also a small vacuum line right behind the intake you'll have to remove the T in it and reconnect it w/out the t. You will have to turn off your AIR codes.
