When Cold, engine sputters ...
Old Feb 26, 2005 | 07:53 AM
JEB99TA's Avatar
Default When Cold, engine sputters ...
After changing plugs, my car seems to be sputtering at low rpm's until it warms up for a few minutes. Any ideas? I've thought maybe I broke a plug wire or that the plug gap should have been closer. They're TR 55's and I gapped them at .045, so, I don't think it's the gap. Also though maybe a plug wasn't tightened enough, but, I know I got them in good and snug. Maybe a coil pack going bad?
Old Feb 26, 2005 | 06:11 PM
JEB99TA's Avatar
I reseated the plug wires and it seems to be OK for now ... did same two weeks ago when I changed plugs. I think maybe I tugged too hard on the a plug wire (naturally it had to be the right rear passenger side) ... go figure ...
Old Feb 26, 2005 | 08:25 PM
kpowr82's Avatar
glad you got it figured out.
BTW, just out of curiosity, are the coil packs on the '99 all bolted up separatley or are the 4 coil packs on each side attached to a single rail?
Old Feb 26, 2005 | 08:35 PM
Blue02Ws6's Avatar
Yeah mine does that also. So it might be the wires huh? BTW thanks for posting a hopeful solution.
Old Feb 26, 2005 | 09:58 PM
JEB99TA's Avatar
The coil packs are mounted inline on each side on a single rail. These rails bolt to the valve covers.
You're welcome.
Old Mar 1, 2005 | 05:10 AM
JEB99TA's Avatar
Default Found the problem ... strange
What sounded like a spark/electrical issue turned out to be the QTEC exhaust cutout plate. I have the one for the adjustable Borla Catback and apparently, it was having a difficult time closing.
It was partially open and it must have developed enough slack or looseness to where the plate was fluttering between mostly open and partially closed. I haven't taken it off yet, however, after persistently using the switch, it FINALLY decided to close and seal completely. Once I got it to finally close, the 'sputter' went away ... what a relief. I guess it died hard and was fun enough to probably go ahead and buy a new one.
Also, it may possibly be the reason it was smoking a little black smoke at WOT ... any thoughts on this?
