No SES light?????
Old Mar 6, 2005 | 08:38 AM
SgtB's Avatar
Exclamation No SES light?????
Hey guys,
I installed SLP LT's and PRY yesterday. 11 1/2 hrs and 2 busted up hands later...... My front O2 sensors are not hooked up because I do not have the extensions yet. However they are hooked up to the headers. I did not put O2 sims on either because I plan on deleted them. My question is "How come I do not have an SES light if no emissions things are hooked up?"
Thanks.
Old Mar 6, 2005 | 10:34 AM
ddelallata's Avatar
give it some time and the light should come on unless the light is burnt already.
Old Mar 6, 2005 | 11:36 AM
SgtB's Avatar
OK I will.
The light is not burnt out. My car only has 17K miles. It comes on when I start the car then turns off.
Old Mar 6, 2005 | 12:40 PM
Full-Force's Avatar
it will come on .... i drove my car about 80 miles before mine come on for having the rear 02's and air off
Old Mar 6, 2005 | 01:15 PM
jimmyblue's Avatar
Moderator
A lot of the codes only set on the 2nd run cycle
in a row with a failure.
Old Mar 7, 2005 | 08:06 AM
LS1s R US's Avatar
Yeah give it time it'll be on before long!
Old Mar 7, 2005 | 08:51 AM
SgtB's Avatar
it went on yesterday when I took it for a cruise...sonce it was 52 and sunny in chitown!! woohoo
anyway, what about the front O2's can these be deleted through the PCM before I gop out and buy extensions?
Old Mar 7, 2005 | 10:27 AM
Ryan02SS's Avatar
Off the top of my head...... The PCM sends a diagnostic to the rear 02's while at cruising speeds, can't remember at what speed and how often. When the PCM does not receive a reply you will get the SES light. Go drive on the freeway for awhile and you will get your SES light.
OT Your driving your car without any 02's hooked up?? My advice would be to get those extensions. You need the front 02's hooked up to determine proper A/F ratio in closed loop running. Only the rear 02's can be deleted.
 Michael S. Palmer
Old Mar 7, 2005 | 12:22 PM
GT Griller's Avatar
I agree. U need the front ones.
Old Mar 7, 2005 | 12:24 PM
Keenov's Avatar
The front ones are needed. Delete the rear O2 sensors.
