ultra z hood; modify
Old Mar 12, 2005 | 01:22 AM
obZidian's Avatar
Default ultra z hood; modify
hey, i have an ultra z hood and before i get into a lid (yes, i do have a stock lid still!!!), i wanted to know if anyone had modified the hood for more air flow, modified a lid or made a custom kit to have better/more air flow or a combination of the two?
Also, i say this stealth intake with a larger, c4 filter. AMde some pretty sweet numbers, has anyone dealt with one?
basically, i want to feed the 408 as much air as possible and optimize the ram air effect of the hood.
any suggestions, comments, flames.
Angel
Old Mar 12, 2005 | 01:28 AM
Wnts2Go10O's Avatar
well theres a kit for lt1 4th gens than seems to be better for ram air so..
Old Mar 12, 2005 | 09:13 AM
obZidian's Avatar
it that the one wiht the open filter box....that sits on top of the motor?
just looked at one of those and that was also a possibility if i could mount on top of the radiator shroud
Old Mar 12, 2005 | 09:23 AM
SgtB's Avatar
Take a look at the K&N FIPK of the Volant Cold Air Induction.
Old Mar 12, 2005 | 11:07 AM
nspr8td lt1's Avatar
the lt1 style ws6 box might work for ya. it sits on top of the radiator with an open element facing up. i dont know if the ultra z hood has provisions to seal up to that style air box.
Old Mar 12, 2005 | 11:45 PM
hardcore4sure's Avatar
Use the WS-6 airbox and cut the baffles in the hood to match up.
Old Mar 13, 2005 | 02:30 AM
TNormZ28's Avatar
Get a lid, and remove any rubber piece is between the lower air box and the sheet metal just below it. A WS6 lower airbox will provide a larger gap between the metal and lower airbox, but not enough that I would think it would make a difference.
Old Mar 13, 2005 | 10:46 PM
obZidian's Avatar
has anyone used a stealth intake before?
