install today!
Old Mar 13, 2005 | 03:27 PM
NviouSS's Avatar
the manifolds are bolted to the cats, which is bolted to the y. putting them in yourself isn't very hard, just takes time. when you go to tq them down, go from the middle out. 11 ft/lbs on the first pass, then 18 ft/lbs on the second pass. open headers is VERY LOUD. it shook my car, house, etc. just idling.
Old Mar 13, 2005 | 03:31 PM
blind527's Avatar
My room is above my garage, and idling with just a cat back shakes my floors. I won't be able to put the y in myself, because it is welded and I dont' have the tools
Old Mar 13, 2005 | 05:08 PM
ProjecT 9's Avatar
Originally Posted by elite22xl
yea slide it in there and i think you have to stand the header up vertical to get it to slide in, should not really run into anything with it
ya that is exactly what i had to do...i wish i knew that yesterday night, could of had it done already, but it sounds awesome!! and once i finally got the header in it just slipped right in...i was going by my pacesetter install from when i did those, but these slide in alil different! but i want to thank Rainman for helping me along with the install...
Jon
Old Mar 13, 2005 | 07:52 PM
Sanders's Avatar
Im gonna be installing my QTPs and OR Y pipe on the 26th. Did you have any trouble with the Y pipe? Thats the part of the install im concerned with.
Old Mar 13, 2005 | 09:13 PM
ProjecT 9's Avatar
nah i didnt have any trouble, it went together pretty easy actually...im going to the exhaust shop tomorrow to do some touch ups on the fitment, then have some of it welded...just to make it alil stronger and more sturdy...good luck man...shouldnt be no problem though
Old Mar 13, 2005 | 09:43 PM
Sanders's Avatar
Good to hear man. Also, how many clamps did you need for the Y? Does the car feel noticeably quicker now?
Old Mar 13, 2005 | 10:06 PM
ProjecT 9's Avatar
i have a catted Y and i had to use 6
-2 for each header collector to the Y (1 for driver side, 1 for passenger side=2)
-2 for the 4'' to 3'' merge from the flowmaster collector to the I pipe
-2 for the driver side cat (1 before it, 1 after it)
unless your planning on changing it out later, i would recommend just getting it welded after you get it on...its more sturdy, and solid feeling...just what i intend on doing atleast..
to be honest i dont really know if its quicker...i went from True Duals to a catted Y and catback...i havent really gotton on it fully yet, b/c i didnt want anything coming loose (my fear of clamps) so after tomorrow ill let you know!
Old Mar 13, 2005 | 10:26 PM
ProjecT 9's Avatar
you know after i installed my new headers and exhaust...i noticed i could hear the valvetrain alot more...like the clicking...anyone else ever notice that?
 Michael S. Palmer
Old Mar 14, 2005 | 04:23 PM
co.6z28's Avatar
silverstreak did your engine throw a code after the install ? just got the headers and catted y in today. just lookin for some tips thanks
Old Mar 14, 2005 | 05:36 PM
ProjecT 9's Avatar
no it didnt throw a code, but i had my rear o2's deleted from my TD install so you will most likely have to get those deleted or get some sims for them...i did how ever get the ses light, b/c i took off my egr and air with it...other then that no biggie...car runs awesome!!!
Jon
Old Mar 14, 2005 | 06:02 PM
co.6z28's Avatar
thanks so when do we hear the sound clip
Old Mar 14, 2005 | 06:05 PM
  #32
ProjecT 9's Avatar
by the time you get a sound clip, you will prolly already have your exhaust on..i have to drive to south carolina tonight!!
but if not then ill get one when i get back to beaufort..
Old Mar 18, 2005 | 11:01 PM
  #33
SmokedOutZ28's Avatar
how easy is it to break the stock manifold bolts loose?? i worried about breaking them off into the head should i be worried about this?
also ive notice on the passenger side the alt braket is held in with exhaust bolt did you guys reuse that bolt or just ditched the bracket?
i have pacesetters on order and should recieve them in a couple of week and will be doing the install myself, ive got o2 extensions for the front sensors and new plugs, wires and o2 when im doing the install. is there anything else i would need?
Old Mar 19, 2005 | 03:25 AM
  #34
NviouSS's Avatar
spray them down with some WD40 and let it soak in over night.
