how do you hook a SLP MAF to a vette?
Old Mar 15, 2005 | 11:10 PM
FroDaddy's Avatar
Default how do you hook a SLP MAF to a vette?
I've got an SLP 85mm MAF that I want to put on my '99 vette. The problem is the SLP plug-in is 3 prong, but it's bigger than the plug that's on my MAF right now... and also I have an IAT sensor to deal with.
Anyone had experience with this that can help? Thanks. I looked on ls1howto, but they only deal with the Z06 85mm MAF
Old Mar 16, 2005 | 08:44 AM
jimmyblue's Avatar
Moderator
My SLP MAF, and all the regular Delphi 85mm MAFs,
are 5-pin plugs. The older 'vettes used the same as
F-body, a 3-pin MAF w/o IAT. I would expect yours
has a 3-wire harness and won't fit the 5-pin MAF.
Casper's Electronics makes adapters, SLP ships an
adaptor with their MAF as well as a piece of Fernco
hose (oohhhh) and a couple of hose clamps (ahhhhh).
You can also get the Casper's adapter harness from
Pace. The Casper's harness comes with all 5 wires
at the MAF end and splits into a 3-wire (MAF) and
2-wire (IAT) which you can plug your two branches
into.
Or, if you're a cheap old bastard who likes to solder
go to a junkyard and get the last foot of MAF harness
cut off a truck.
