are the tb for the 99-03 trucks the same as ls1
Old Mar 18, 2005 | 09:56 PM
flippincamaro's Avatar
Default are the tb for the 99-03 trucks the same as ls1
okay i found a tb spacer i want cheap but it says it is for the 4.8,5.3,6.0 engines will it fit my ls1 5.7 engine with the ls6 intake if not what is the diffrence thanks kenny
Old Mar 18, 2005 | 09:58 PM
Bo White's Avatar
It will bolt up but do not know if it'll work well or not.
Old Mar 18, 2005 | 10:27 PM
i thought it would bolt up cause the tb looks the same on the outside. But does anyone know if it is the same holes or what not. same size inlets
Old Mar 18, 2005 | 11:02 PM
Bo White's Avatar
The 98-99 F-body and cable driven truck TBs will interchange with each other except the slight difference in the coolant line hook ups so I do not think it will be a problem.
Old Mar 18, 2005 | 11:03 PM
great i got rid of the coolant lines on my tb anyways but their not diffrent size inlets are they? that is my main worry thanks for the help Bo
Old Mar 18, 2005 | 11:09 PM
Bo White's Avatar
Just yell if ya need anything.
