Odd oil pressure reading after Mac Header install
Old Mar 24, 2005 | 08:35 AM
silver02Z's Avatar
Default Odd oil pressure reading after Mac Header install
I've noticed that my oil pressure isn't reading as high as it did before I installed my headers...I haven't noticed an oil leaking so I don't think I broke my oil sending unit. My oil pressure has never been 40 at idle and usually runs around 60-70 all the time. Now it seems to be jumpy at idle 35-45 but when I stomp on it, 60-70. Thanks in advance for your help!
Kevin
Old Mar 24, 2005 | 09:24 AM
1999T/A's Avatar
Mine did the same thing . Dont know why but im not worried at all about it .
Old Mar 24, 2005 | 03:34 PM
TS6's Avatar
TS6
Old oil? Could also be the headers are heating up the oil since they are closer to the filter/ pan area.
Old Mar 24, 2005 | 06:06 PM
silver02Z's Avatar
I don't thinkg the oil even has 3000 on it and it's mobil 1 5w30. I'm also noticing that the starter is dragging after running a while..I assume this is the heat from the headers...Does anyone use a heat shield for their starter?
Kevin
Old Mar 24, 2005 | 08:47 PM
ddelallata's Avatar
Kevin
I haven't noticed any difference. Are your headers coated?
Old Mar 24, 2005 | 10:17 PM
silver02Z's Avatar
The Mac Mids come coated but I don't think it's a jet hot coating???
Old Mar 25, 2005 | 02:56 AM
John_D.'s Avatar
Kevin
I made one for mine.
Did it at the same time as the v6 to v8 swap, which was when I did the heads/cam/intake/headers too...
Old Mar 25, 2005 | 05:00 AM
TNormZ28's Avatar
It's fine.
Old Mar 25, 2005 | 08:25 AM
1999T/A's Avatar
No heat shield for my starter and it works fine every time. Sounds like your starter might be on its way out .
Old Mar 25, 2005 | 08:40 AM
silver02Z's Avatar
The thing is that it was just fine before I installed the headers..Everything is acting funky now...I should have just left it alone!
Old Mar 25, 2005 | 08:43 AM
Keenov's Avatar
Buy a civic
Old Mar 25, 2005 | 09:33 AM
SS-35th's Avatar
Do you have a picture of the headers? If they are flat gray then I don't think they're coated. I bought a set (new) that are coated and they have a chrome like finish.
Old Mar 25, 2005 | 06:42 PM
SmokingWS6's Avatar
60-70 all the time isn't normal.
If its 35-45(warm) at idle and raises with rpm to 70 or so is perfectly normal. Perhaps you fixed the sensor and didn't even know it.
Old Mar 28, 2005 | 11:10 PM
JRracing's Avatar
Mine where on the car when i got it & i've had it 2 yrs. I have none of these problems. oil presure is seems normal.the starter may have been on its way!
Old Mar 29, 2005 | 12:19 AM
silver02Z's Avatar
I just finished changing the oil. I went with German Castrol 0w30 and a K&N HP2600 filter. Oil pressure is back to normal (for my car)! The starter isn't acting up anymore either. I think my car was just having a bad day or something????
Kevin
