Throttle Body Porting 101
Old Oct 17, 2007 | 09:43 PM
ae13291's Avatar
so how do i 100% mak sure it is at 90 degrees opening???
Old Oct 17, 2007 | 09:44 PM
ae13291's Avatar
and where do i check ther voltage at???
Old Oct 17, 2007 | 10:00 PM
Smokin87TA's Avatar
Restricted User
you can check the voltage by using the blue wire that goes into the tps sensor. You need to connect a volt meter to the blue wire and ground grind a little, then check, and repeat till your close to 4.69ish, just dont go over 4.71. Tim
Old Oct 17, 2007 | 10:02 PM
Smokin87TA's Avatar
Restricted User
here is a good write up and is easy to follow. Tim
http://www.installuniversity.com/ins...sity/index.htm
Old Oct 18, 2007 | 12:51 AM
ae13291's Avatar
and what type of epoxy can i use any specific kinds??
