how is the flowmaster american thunder?
Old Apr 4, 2005 | 02:01 PM
1999T/A's Avatar
Originally Posted by SouthFL.02.SS
Pretty much the only Hooker catback available. I think it does use the Aerochamber style muffler.
Thats what I thought . Thanks for the info !
Old Apr 4, 2005 | 02:05 PM
~JOSHUA's Avatar
You get what you pay for bro. $170 is not bad- better than stock, but.....
Try the new Loudmouth 2 for $350. Stainless and people have been saying some good things about it. Not as raspy and loud as the original. I have the Flowmaster 40 series on my daily driver '94, sounds good, but.... who cares?
Old Apr 5, 2005 | 12:26 AM
tuffluck's Avatar
i turned my cutout today. i had an exhaust shop do it for $20. it's about 1.5 inches higher than normal. in fact, it's still the lowest point on my car - MAYBE!! and if it is, it's only the lowest by about a quarter of an inch. i'm much, much happier now.
the only concern i have is that the cutout and i-pipe are both about .5 inches away from the underside of my car. i'm afraid that either one of them is going to flex and dent the floorboard or that the hot exhaust might slowly do damage to the metal underneath? thoughts?
Old Apr 5, 2005 | 12:30 AM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
Many of us have exhaust pipes/ LT collectors/ merges/ junctions really close to the floorboard and/or fuel lines (in the case of duals). I wouldn't sweat it. Sleep well.
Old Apr 5, 2005 | 08:45 AM
Keenov's Avatar
Yea, my exhaust is close to my floorboards. I made sure I had only an index finger of clearance between them, so that ground clearance was not a problem. No banging at all I also have poly motor mounts, so my exhaust is pretty still.
Mine is not that close to the fuel lines though, they are flipped.
Old Apr 5, 2005 | 08:49 AM
redline2k's Avatar
Go ahead and purchase the worst flowing catback on the market.
That is funny considering I had this cat back and swapped it to a magnaflow because everyone said I would pick up power. The magna flow only made the car quiet. No gain in performance at all.
Old Apr 5, 2005 | 09:27 AM
Keenov's Avatar
The issue with the flowmaster is that one person tested it against another catback and posted it on here. The results spread like a the plague.
Old Apr 5, 2005 | 01:15 PM
SgtB's Avatar
I like the way mine sounds. I have no problems as of yet and I have a pretty good feeling it will perform well on teh 16th at Route 66 in Joliet.
Old Apr 5, 2005 | 01:29 PM
tuffluck's Avatar
mine is not that far away i don't believe. it's just that the welder used a 3" to fit around the stock 2.75" pipe in order to weld it back together, so it runs very close to the floorboard at one point. i'm guessing this is probably no different at all than having a 3" catback. who knows? but i don't hear it clunk at all, so i'm assuming it's not a problem.
Old Apr 5, 2005 | 01:52 PM
tuffluck's Avatar
in fact, now that i look at it, the i-pipe is pretty much resting against the floorboard in the rear. and if it isn't, the space is very narrow between the pipe and the floorboard. in addition, the the screw on the cutout is about a quarter of an inch away from the floorboard. you think i'm going to see any problems with this?
Old Apr 5, 2005 | 03:25 PM
Keenov's Avatar
If it doesn't bang then you shouldn't have any problems.
Old Apr 5, 2005 | 05:23 PM
  #32
tuffluck's Avatar
okay. i'm not sure how it's touching the metal underneath, considering it's still stock. the welder must not have welded it back in the form of the stock location. i don't really know.
how many inches does the i-pipe flex under the most extreme conditions? .2 inches or something?
Old Apr 5, 2005 | 08:06 PM
  #33
!LS1 11 Second Club
Dude, if you would have a look under my car you'd have a seizure. If it ain't bangin' don't fret.
Old Apr 5, 2005 | 08:47 PM
  #34
tuffluck's Avatar
haha. well, i won't worry with it then. i haven't heard it bang, so i am not going to fret. it might be making small contacts with minimal sound at most, but i've driven over some pretty bumpy road and normally only heard the usual noises these crazy f-bodies make
Old Apr 6, 2005 | 08:06 AM
  #35
67SS&99SS's Avatar
I bought the flowmaster american thunder catback about 2 years ago and it was the worst mistake that I ever made. It popped like everything going down the road and it didn't really sound that good unless I went wot. Thats about the only time I heard the catback. I have since changed my setup to headers/true duals and couldn't be happier. Save your money and get a quality exhaust the first time.
