80mm TB, will it make more power?
Old Apr 10, 2005 | 07:41 PM
02-WS6-Freebird's Avatar
Default 80mm TB, will it make more power?
I have a 2002 TA, mods are lid, K&N, ported fact. TB, LT's, 2.5" true duals, 2800 stall and 220/224 cam, will a 80mm really help or make more hp and would it need to be re-tuned? thanks for any advise.
Old Apr 10, 2005 | 07:55 PM
jrp's Avatar
jrp
SN95 Director
just get a standard oem parted TB.
Old Apr 10, 2005 | 11:20 PM
1fstbird's Avatar
i switched to a bbk 80mm tb and i did feel a little difference in the performance of the bird
Old Apr 10, 2005 | 11:29 PM
BackinBlack02SS's Avatar
The LS1/LS6 intake manifold is only 75mm, so going with anything bigger than 75 mm is pointless, and may actually cause turbulance and hurt performance.
Old Apr 11, 2005 | 01:21 AM
Scoobie's Avatar
Correct about the turbulence, best option is to port stock TB. If you want to spend more money, get the MTI Billet TB. Cost is around the same as the BBK, much nicer unit though. Unless you are going with a 90 mm intake manifold, these are your best bets.
Old Apr 11, 2005 | 04:10 AM
Wicked_Hugger99's Avatar
Yep, I agree scoobie!
you got an LS6 intake so just stick w/ a ported stock TB unless you wanna get sum bling, then go w/ the MTI unit.
BBK is a waste.
